No power inside the car
Hi all,
I recently purchased a 2022 GLC Coupe AMG. The car was flooded a year ago and was sitting in someone's house for a whole year. I charged the batter and inside the engine gets power but nothing inside the car. No cluster, no way to put in neutral. Door lights dont come on as well so suspect its not the EIS. IS there a master fuse/fuse box that could be causing this? TIA
You bought a car that was in a flood, then it sat(inside a house?), and corroded for a year? Tf? Hopefully it was dirt cheap, because I suspect you will be chasing this problem, and many other problems down the road for as long as you own it. These things are like computers on wheels, and water is not your friend. Best of luck, as I wouldn't even know where to start with this one.
Same issues
Hi all,
hey did you find the problem I’m having the issue flood damage nothing comes on as well thanks
Hi all,
The main wiring under the front seats were mainly affected as well as wiring under the rear cargo area. I'm giving you this story to let you know that these things are filled with important wiring that can be affected by flooding. Unless you replace ALL the modules that were under water, along with all the wiring and all the connectors, you're never going to get ahead of the myriad of problems. And this can take tens of thousands of dollars to replace. Be prepared to spend 10 to 20 thousand dollars to have fixed.
2014 ML63, 2018 GLC43, 1929 DB victory six sports roadster
If it’s insured they will write it off.
I actually bought it from the auction pretty cheap it’s a 2022 with 24 thousand miles came from a flood
and I try to remove the seats but I have no power so I been thinking of ways to get the seats removed , I got 4 bolts removed just gotta access the other 4
How much water got into it. You would almost need to buy another accident damaged car and swap all the damaged panels onto it.
It’s like pulling a laptop out of a swimming pool leaving the battery in it connected for a week and expecting to get it to work. My 2014 ML has 58 modules I’d hate to think how many a 22 has.
