GLC63s SUV suspension mods?
Old Jan 17, 2025 | 05:04 PM
kaiyabunga's Avatar
‘19 GLC63s X253
New here. Looking for some type of lowering system. Tried looking on google and don’t see one. I don’t just want lowering springs. I want a full kit
Old Jan 18, 2025 | 06:23 AM
4npower's Avatar
2019 GLC 63, 2020 C43 coupe
GLC63 has air suspension(no springs), so the options are lowering links, or a module you plug into obd port. I went with lowering links.
Old Jan 18, 2025 | 10:23 AM
kaiyabunga's Avatar
‘19 GLC63s X253
Thank you. Very new to modding so clueless. Will look into lowering links
Old Jan 18, 2025 | 10:25 AM
kaiyabunga's Avatar
‘19 GLC63s X253
Which brand recommendation?
I see Airmatic Lowering Links
Old Jan 18, 2025 | 11:19 AM
4npower's Avatar
I got mine on Ebay in 2018 when I got my GLC43. I used the same ones on the 63 in 2021, so tbh, I don't remember lol
They are pretty simple in design, so maybe a quick search and don't spend a ton. Mine were like $150 back then.
Old Jan 18, 2025 | 11:38 AM
C43 Fun Haver's Avatar
2015 ML63
I don't have the same vehicle as you guys, but for my ML63 I went with MWmods OBD module. Takes 30 seconds to adjust your ride height. You can select custom levels to get it where you want it. I can get it too about -55mm in the front and -58mm in the rear when I slam it down.
I did order the Ghost level links for my ML but in order for them to work, I will have to swap the bushings out of the OEM links. I still have them in the box now 2 years later.
The obd module i just leave in the center console and adjust whenever I need. super easy.
