2020 GLE450 Tire Pressure
"Tire pressure listing inside driver’s door is size specific for 21s – 34F/39R. Notation inside fuel flap (non-specific) is 31F/31R normal; 31F/39R loaded. I think I will go 34/34 for normal use. Not sure why Mercedes does this (was same on my ’12); it’s confusing."
It is very confusing for the owner. I think 31 is a little low, but if you're after comfort it is safe. I would go 33F/33R for unloaded use (or at least 32/32), raising the rear for 4 passengers + luggage or towing. My '12 ML with 20s was posted similarly with 32 psi minimum. Raising the front tire pressure decreases potential understeer, but in the non-AMG models I don't think that is a factor, but it will sharpen steering slightly.
Where is that middle sticker located?
The fuel filler door is the manufacturer's recommendation for inflation pressures.
I think they allow sun visors on SUV's now, that don't have rollover warnings.
Soon, we'll have World Class headlights, if those Bureaucrats can figure out how to read the Law. They have two years to write the Rules, then hold hearings, then re-write, then two more rounds of hearings and objections, then a final Rule. We'll see (headlight pun).
