GLE53 vs GLE580
Old Jun 7, 2019 | 11:31 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
GLE53 vs GLE580
I'm thinking of buying a new GLE but am waiting for more high output engines.
Not sure I will do 63 this time around since my 2018 E63S is a bit harsh for our roads. So am choosing between 53 and 580.
53 has the AMG badge and bodywork which I like. But the 580 is likely faster. The Dealer Ordering Guide is quoting a 0-60 time of 4.9 on the 580 and I've read rumors it is more like 5.3 on the GLE53. Plus above 60 the V8 will be more compelling.
But will the 580 have the nicer interiors and finishes of the AMG models? Nappa leather, alcantara headliner, wider tires, sport exhaust etc.
Any thoughts?
Old Jun 8, 2019 | 06:57 AM
caspertm's Avatar
1998 C200, 2004 ML350, 2015 C250 & 2017 GLE 43AMG Coupe
I have a 43Coupe. In my opinion as a complete package including fun factor its only second to the 63.
I would go for the 53.
Old Jun 8, 2019 | 07:48 AM
Erasmo's Avatar
Range rover sport 5.0 supercharger
Any thoughts?
If performances are really important, I would wait for the GLE 580 or maybe looking somewhere else.
2 thinghs disappointed me with the GLE 450, fuel economy and performances.
I recently did a pretty long test drive of the GLE 450, is not slow, but since I'm used to a 510 hp range sport v8, that makes the 0-60 mph in 4.5 seconds or less, I felt that the engine still lacks something. The V8 should be fine but probably still slower than my range sport. First, because of th 20-25 hp less, second because of the better weight distribution on the land rover (the range sport has a weight distribution of 50/50, the gle around 54/46). Weight distribution is very important for acceleration, just look to the porsche 911.
I m also waiting to test drive the new aviator with +450hp and crazy 800 lb ft of torque.
Also, if can be helpful, here is the test drive of the GLE 450 by caranddriver https://www.caranddriver.com/reviews...y-the-numbers/
Old Jun 8, 2019 | 12:00 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
GLE 580 vs. GLE 53
Any thoughts?
There are a few key considerations.
  • Factory numbers are for 580/53 the following: HP (w/o EQ Boost) - 483/429; Torque - 516/384; 0-60 - 4.9/5.2, so 580 is faster, but not by a huge margin. V8 should sound better. 53 will get better mileage.
  • The 580 is not a true AMG model, so interior and other options are pretty much the same as the lower models, except you can get the 22" wheels.
  • The 53 is AMG-badged (body & brakes), and gets round quad exhaust, and also the 22" wheels as a choice. The interior shown so far has red accents: seatbelts, piping and steering wheel marker.
  • The 580 has Airmatic standard, with E-ABC as an expensive option. The GLE will have Airmatic with Active Ride Control. This may be the best sport suspension with active roll control (a further development of the Active Curve I had on my '12 ML); less expensive and complicated than E-ABC. There are a few other AMG-specific things like MBUX settings with the 53.
  • Timing may be a factor. Rumor is that the 580 is a short-term model until the 63 comes out, then it will go away (much like the '19 GLE 400 was a stopgap until the '20 GLE 450 came out). 580 is scheduled for Q4 this year and 53 sometime next year (as well as the 63, I assume)
Old Jun 8, 2019 | 06:37 PM
DMG's Avatar
DMG
2001 G500
  • complicated than E-ABC. There are a few other AMG-specific things like MBUX settings with the 53.
Sounds like you get the 63 Engine without sacrificing some of the comfort (sport seats vs non sport seats) with the 580. Minus the styling, better tuned engine, and more ideal suspension. And sorry for going off topic comparing to the 63 which seems more apropos. My question is does the 580 command a premium down the road (no pun intended) due to its limited production release? Any thoughts on that from the veterans (looking at you Greg)?
Old Jun 8, 2019 | 07:36 PM
GLE 580 vs. 53 vs. 63
Well, the 580 is a V8 but nowhere near the individually-built 63 version, which will have another 100 hp or more. And the E-ABC suspension is another $8,200, and it really has comfort as its strong point, not all out sportiness. If you want a V8 that is more comfort-oriented, it might be the ticket. I think the suspension in the 53 will be sportier without a severe AMG comfort penalty. The 580 will not have the cachet of an AMG model.
I am not an expert at used Mercedes prices. My guess is it will probably hold value a little better than the 450, but not as well as an AMG.
Old Jun 9, 2019 | 02:37 AM
bkdc's Avatar
2015 S550, 2017 GLS450
As to the suspension, AMG ride control is really only useful on the track and offers more fine tuning than the standard Dynamic Select. No one is going to track his SUV. I prefer the higher displacement biturbo V8 over the supercharged turbo in-line 6 because I believe that’s running an engine at lower compression leads to greater longevity. Other than appearance trims and weight savings on the six cylinder, they will both be great cars with plenty of power for daily driving. Both V8 and L6 engines are buttery smooth.
Old Jun 9, 2019 | 11:33 AM
Active Ride Control
I disagree with this. Active Ride Control manages vehicle roll in typical driving situations without the penalty imposed by stiffer antiroll bars. It's of less benefit on the freeway, but in any curvy road driving it would be a nice feature. As I said, I had the previous version called Active Curve on my non-AMG '12 ML 350 and liked it a lot. The new one driven by the 48 volt system has got to be even better.
"Total stabilization: AMG ACTIVE RIDE CONTROL
Redeveloped in Affalterbach, AMG ACTIVE RIDE CONTROL based on AIRMATIC forms the basis of a driving experience characterized by a high level of agility, neutral cornering behavior and optimal traction. A new feature makes a significant contribution to the AMG-specific tuning for high levels of driving dynamics: the active roll stabilization with two electro-mechanical actuators working independently of one another on the front and rear axle, as well as fully variable torque distribution.
Not only does the system reduce rolling movements when cornering, it also enables more precise tuning of cornering and load changes. In addition, it increases driving comfort when driving straight ahead. Movements in the body can be actively and optimally adjusted to driving conditions."
Old Jun 9, 2019 | 10:20 PM
fabbrisd1's Avatar
A gaggle of MB's
The "order window" for the GLS580 will be very/very short - will Open soon and Close/Reach-Capacity like a camera shutter.
Spec it with your dealer (best guess) - give them a deposit - that way they can have your ordered tee'd up...
Old Jun 10, 2019 | 04:05 AM
Chaznik's Avatar
C43
Thought this may be of interest?
Old Jun 10, 2019 | 07:01 AM
tinman831's Avatar
2020 GLE
Any idea when they’re expected to come in?
Old Jun 10, 2019 | 07:44 PM
bkdc's Avatar
With the GLE production delays in Alabama, I'm a little hesitant to pull the trigger on an order.
Old Jun 10, 2019 | 08:10 PM
tery's Avatar
CLK320
Don’t fall for the trap to order one.
Old Jun 10, 2019 | 08:28 PM
tinman831's Avatar
2020 GLE
Or you just might end up with an awesome suv in your driveway.
Old Jun 13, 2019 | 08:44 AM
ShrimpKing's Avatar
GLE 450 And some not MB cars
Any one have GLE 53 ordering guid to share?
Old Jun 23, 2019 | 07:39 PM
GLS 580 review
Here's a review of the GLS 580; That engine sounds good!
Old Jun 28, 2019 | 08:05 PM
tery's Avatar
CLK320
I am thinking switching order to 580 now, since there is no word when the 450 will arrive. If the 580 will be deliver end of the year I think is worth it.
Old Jun 28, 2019 | 08:30 PM
tinman831's Avatar
2020 GLE
My anticipated August delivery is now into September. With all the delays I’m not too hopeful. If it’s pushed into October I’ll wait for the 580.
Old Aug 11, 2019 | 08:38 PM
GLE 53 per CLS 53
This review of the CLS 53 gives some good insight in what to expect with the GLE 53's drivetrain: https://autoweek.com/article/car-rev...ent=hero-image
Sounds like it should be great!. The CLS 53 base price is 17% more than the CLS 450; that markup would put an GLE 53 base at about $71,500.
Old Aug 29, 2019 | 09:05 AM
Gle 53 orders open?
Unfortunately, I don't think this applies to the US, but Daimler press release 8.29.19 (US can't be far behind): "Mercedes-AMG GLE 53 4MATIC+ available at dealers from November: Powerful SUV trendsetter can now be ordered"
https://media.daimler.com/marsMediaS...l?oid=44248671
Old Aug 29, 2019 | 10:26 AM
turko's Avatar
2020 GLE 450
It's up on the german konfigurator
Old Aug 29, 2019 | 01:43 PM
Chaznik's Avatar
C43
Cant seem to locate it?
Old Aug 29, 2019 | 02:19 PM
turko's Avatar
2020 GLE 450
https://www.mercedes-benz.de/passeng...dyId=OFFROADER
Click on the arrow to change the model version and should be the last one
Old Aug 29, 2019 | 02:39 PM
Chaznik's Avatar
C43
Perfect thank you...done my spec and it’s €125k!!!
Old Aug 29, 2019 | 03:02 PM
tery's Avatar
CLK320
You can placed order for GLE 53 in North America I think since two weeks ago ( at least in Canada ) , the dealer has order guide also just no pricing.
