Key Fob Fable
I don't know the exact time before the key goes to sleep mode, but you can manually trigger it by pressing the lock button twice in quick succession.
For mine issue, its the first type. Before getting the new key, almost after any amount of drive, after getting off the car and trying to lock the door with the sensor, it wouldn't work until I shake the key fob.
I wish Mercedes could change the design, so that if the key is detected inside the car while running, it should keep the key "awake". That way, the "time to sleep" won't matter as much.
The problem is that the "light sleep" doesn't awaken as designed, it should wake up with the motion created when leaving the car but sometimes it doesn't.
I think yours and mine are different issue. Mine is either the key go to sleep to early, or the motion sensor doesn't work correctly (now that I think of it), and new key seems to fix it so far.
As for yours, it could be the car not recognizing the key from time to time.
You mentioned that your dealer performed some kind of software update (which I believe is on the car side, as I don't believe you can update the software on the key), which is why I think your issue might be different than mine.
By the way, did the new key + software update fix the issue for you?
I am always dubious when they say that they have carried out a software update, I believe that is to pacify you that they have done something.
(sorry I got confused between you and bkushner which did got a new key)
To be honest it isn't much of an issue to me but they aren't correct and will eventually will be replaced.
Unfortunately some Fobs don’t wake up properly and may go to sleep prematurely. They have a new Fob and I’m sure that they will come in new cars. The production numbers may not be adequate to also provide them to the replacement parts supply chain for now.
So for proof, I took several video’s with my phone showing the malfunction-describing how long I had been driving-shaking the Fob to show it working again. I also described the frequency that it occurred by tracking trips with a failure percentage. That provided the Dealer the necessary documentation of the malfunction. They also began to realize that it becomes more than just a minor inconvenience when it happens so often.
At least 4 members of the service department witnessed the fact that the door would not lock after exiting the vehicle. I provided them videos I took of the issue when the car would not lock when I exited. I provided them with printouts of some of the comments in this thread and provided a link. I showed them the solution that Ron S finally got. This is my 3rd Mercedes so I am pretty sure I know how to lock the doors. Yet even on the day that they finally ordered the new key fobs, they still didn't believe an issue existed.
Thanks to Ron S and all who participated in this thread so I at least had some fodder to use against the service department that just thought I was crazy.
