Customization of MBUX
Old Jul 30, 2019 | 12:29 PM
bad habit's Avatar
A
There could be a difference as to how those functions are setup for US/UK Customers
Old Jul 30, 2019 | 01:17 PM
Philamg's Avatar
GLC 450
Originally Posted by GregW / Oregon
Guess you're SPECIAL
Just pointing out that the car has to be in gear to work.
Old Jul 30, 2019 | 02:10 PM
Philamg's Avatar
GLC 450
Works for RonS from Boise and St George, also was sadguys original suggestion but not sure where he is located.
Old Jul 30, 2019 | 06:02 PM
sadguy's Avatar
GLE450
Canada.
Old Jul 30, 2019 | 06:09 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Not just in gear, apparently, but moving. That makes it a little less useful when you are trying to turn on the front wide view camera when inching out of an obscured parking space.
Old Jul 30, 2019 | 06:15 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Originally Posted by sadguy
Canada.
Thank you, a great shortcut. It may depend on your packages but it works for me in the US.
Now if someone can figure a one touch to turn off Active Lane Keep Assist I will be very pleased. I’m going to write a complaint to Mercedes support not that I have high hopes. I know of no other vehicle that you have to turn it off every time you start the car.
Old Jul 30, 2019 | 07:13 PM
  #32
Philamg's Avatar
GLC 450
On mine the camera comes on when not moving but the car is in gear which means you can select the wide view on the screen before coming out of a parking place. May be to do with package if button works as Ron S says but would have thought if you have the 360 degree camera it should work..
Old Jul 30, 2019 | 07:27 PM
  #33
Accessing camera views
Not really an issue for me, because the Parking Assist button brings up all the options with one touch.
Old Jul 30, 2019 | 07:46 PM
  #34
Ron.s's Avatar
I assume you are pushing the button once and then again holding it down for a second or so. It’s pretty neat since you can do it approaching a parking space and it gives the front and rear view. There is a speed limiter because I tried at 40 something and got a message that it wouldn’t activate because of the speed.
Old Jul 30, 2019 | 07:53 PM
  #35
You can just push it once and choose from the view menu along the right side of the display.
Old Jul 30, 2019 | 08:33 PM
  #36
Ron.s's Avatar
The other option can be done without taking your eyes off the road.
Old Jul 30, 2019 | 10:11 PM
  #37
Well, when I want to engage the camera views other than rear, I am not driving. I am pulling out of an obscured parking spot, or pulling up to a wall or other object slowly.
Old Jul 30, 2019 | 10:17 PM
  #38
Configuring "Lowering when getting In/Out"
I/m not sure if the is just an E-ABC thing, or also Airmatic. But under Vehicle Setting/Quick Access there is an option to lower the car to the lowest setting when you exit it. However, I've found you have to go into Quick Access and do this each time you leave the vehicle. If anyone knows a way to configure this to happen every time that would be great. Would make it easier for my 5'-4" wife. Nowhere that I can find does the owner's manual mention this feature or even Quick Access. I would expect the manual like most to have a full diagram of all the MBUX settings, but it's not found. Pretty poor!
Old Jul 31, 2019 | 02:52 AM
  #39
Philamg's Avatar
GLC 450
I don't have e-abc not available in uk but it is the same on my car you have to select it each time, I have more options in my quick access, will take a photo later, assume you can add options to easy access and select which ones you want in there.
Back on selecting front camera, I wanted to be able to select it for pulling into a parking spot forwards, you can see the lines of parking spot and as it automatically selects the front camera you only have to press one button. When using parking assist button you have to press it and then go up to the screen to select front camera.
Old Jul 31, 2019 | 04:38 AM
  #40
Philamg's Avatar
GLC 450
Here is my quick access screen, reading downwards from top left: Parktronic - Active steering assist - Tow away protection - Lower when entering - Active lane keep assist - HUD - Interior motion sensor..
It looks like there is space for another on bottom right but I don't know if you can add options.
Old Jul 31, 2019 | 10:15 AM
  #41
turko's Avatar
2020 GLE 450
Found this in the AIRMATIC section of the manual. Which seems like where you are. Not working for you?
Old Jul 31, 2019 | 10:32 AM
  #42
Easy entry/exit
I didn't see that because the same is not in the E-ABC section. It works, it's just you have to set it each time you are preparing to leave the vehicle, rather than always activating when you turn the vehicle off.
Old Aug 1, 2019 | 03:22 AM
  #43
JaCe88's Avatar
GLE 300d (v167)
Works parked and in DRIVE for me, small press vehicle settings, longer press camera.
Same here. I’m surprised!
Old Aug 1, 2019 | 04:50 AM
  #44
Philamg's Avatar
GLC 450
No surprise, spoke to the service department and that's how it works, if the camera isn't appearing after long press of quick access button WITH CAR IN DRIVE then that is the surprise and it is a fault. Tried it on 3 GLE'S they have at the dealers and worked on all of them. I don't believe it is just on UK cars as others have said it works, DOESN'T work if the car is in neutral.
Old Aug 1, 2019 | 10:14 AM
  #45
Calling up front view camera
Okay, working for me now - user error!
Old Aug 1, 2019 | 10:42 AM
  #46
Ron.s's Avatar
I had mine set to lower on exit in another section of Settings and it worked without doing it every time. Just like with Quick Access but I remember it to be on Exit, could be wrong. It worked for 2 months. After my OTA update all my personalized settings were erased. Now I can’t find that original option and mine requires reset each time. My point is that it is possible, I need to spend some time and go through all of the settings again to see if I missed it. The MBUX as we know is a work in progress so hoping that these are going to be fixed in the future.
Is the best way to address our concerns through Customer Service or does Mercedes have a product improvement liaison? If enough of us point out needed changes it might help.
Here are some suggestions on my list:
First is the OTA update with no notice it happened, nothing about changes made and is it necessary to reset to Factory Settings.
Second is making ALKA off or on until changed by the driver.
Third is leaving the Driving Mode in the last Setting. If I put mine in Individual Mode why keep recycling back to Comfort?
Forth will now be the Lower when enter/exit setting to remain as set by the driver.
Old Aug 1, 2019 | 11:29 AM
  #47
MBUX
Fourth will now be the Lower when enter/exit setting to remain as set by the driver.
To me, the easiest way to configure profile and settings would be to have a "save current settings" button in profiles. Currently I find it hard to change one little thing without starting over, but maybe I just haven't explored enough.
Old Aug 1, 2019 | 06:12 PM
  #48
Philamg's Avatar
GLC 450
User error from me as well Greg, if you enter the car and keep your finger on quick access button it comes up with message function not available turn on ignition. If you turn on ignition or start car keeping finger on button brings up camera, no need to have car in drive.
Old Aug 1, 2019 | 06:16 PM
  #49
Philamg's Avatar
GLC 450
Mine has done an OTA update and didn't have to reset.
Car remembers last setting if restarted within certain time, not sure what it is on GLE but on GLC was 8 hours and then reverts to comfort.
Old Aug 1, 2019 | 06:42 PM
  #50
Ron.s's Avatar
My Drive Mode resets in less than an hour but stays 10-15 minutes after the ignition is turned off. I’ve never tried to pin it down exactly.
Back to the lower for entry setting-mine doesn’t do anything until the car is turned off and my door is closed after the updates. Before it dropped as soon as the ignition was turned off so it worked for exit as well as entry. Is that the way other cars work? If so it’s really kind of a poor design.
For a short time my doors auto locked when the lights turned off. This was handy when the Key Fobs were acting up. Now I can’t find a setting if there was one. I think I saw auto lock but that seems to be for locking when you drive. Back to the drawing board.
