Possible for permanent ECO mode?
Old Oct 22, 2019 | 12:03 PM
adeels's Avatar
GLE350 2020
Hi, first time poster.
Is it possible to always have the ECO mode on (instead of comfort)? I've gone into the vechile settings, and placed it on the ECO when starting the car, but it hasn't been doing the trick.
Thanks for your help!
Old Oct 22, 2019 | 01:48 PM
maalox's Avatar
Page 174 of the Owner Manual has this, not sure if it helps?
Configuring DYNAMIC SELECT (multimedia system)
Home -> Settings -> Vehicle -> DYNAMIC SELECT
Switching the reset display on/off
Switch Request at Start on or off.
Function on: the next time the vehicle is started a prompt appears asking whether the last active drive program should be restored. If the ECO start/stop function was deactivated, an additional prompt appears asking if the function should remain deactivated.
The prompt appears only if the previously active settings deviate from the standard settings.
Function off: the next time the vehicle is started the C drive program is set automatically. The ECO start/stop function is activated automatically.
This function must be activated for each user profile separately. Only when this function is activated will the drive program and Eco start/stop setting for the previous journey be saved for the respective user profile.
