22 inch wheels
Old Nov 23, 2019 | 03:40 PM
Spleen's Avatar
Mercedes GLE 450
22 inch wheels
Hi all
first post....
I recently got my 2019 GLE 450 with 22 inch AMG wheels and I wanted to check if others had any issues with their tyre pressures on this wheel size?
The sticker in the fuel cap advises 32psi all round. I did this and it felt like driving a boat. Does anyone have any suggestions? MB UK and the Dealer don't know the answer, they both suggested it was whatever the fuel cap sticker says.
The front tyres are 285/40, rears are 325/35 (all R22)
thanks/all the best
Ron
Old Nov 23, 2019 | 05:28 PM
Henry Stark's Avatar
GLC63S
Originally Posted by Spleen
Hi all
first post....
thanks/all the best
Ron
Did you check the label by the drivers door. Should be closer to 38 psi or higher if I had to guess?
Old Nov 23, 2019 | 05:45 PM
Philamg's Avatar
GLC 450
I have the 22 inch wheels and run them at 34 with no problem, as you say the advised setting is 32.
Old Nov 24, 2019 | 08:25 AM
Spleen's Avatar
Mercedes GLE 450
I couldn't see one there Henry but will check again, thanks!
Old Nov 24, 2019 | 08:27 AM
Spleen's Avatar
Mercedes GLE 450
Great, thanks for that Phil, I will give that a go. I changed the rears to 34 and that seemed to improve it, I'll do the fronts too.
All the best
Ron
Old Nov 24, 2019 | 10:21 AM
Philamg's Avatar
GLC 450
The tyre pressures are shown on the inside of the fuel filler cap not the drivers door, that's in the UK.
Old Nov 24, 2019 | 10:49 AM
Spleen's Avatar
Mercedes GLE 450
Sorted now, thanks. I changed to 34 all round and tested it this afternoon, much better, thanks for the tip
All the best
Old Nov 24, 2019 | 10:51 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Tire pressure confusion
38 is way to high. As has been reported previously there are 3 different tire pressure labels that do not entirely agree. The one on the fuel filler door is the closest; running a little higher is okay, but 38, except in the rear when fully loaded, would give an extremely hard ride. My 21s are listed at 31/31 for normal loads and I think they are fine even for hard driving at 32.
Old Nov 24, 2019 | 11:08 AM
GLC63S
If you prefer driving a soggy noodle I’m sure it’s great!
