Hello guys. I have a 2020 GLE 350 with stock 20s. I want to install some bigger tires, as the current ones look small. Which size would fit perfectly without making so many adjustments? I was thinking about 21. Hopefully something not staggered, as the current ones are not staggered.
I appreciate all the suggestions
GregW / Oregon
close
- Join DateJul 2003
- LocationLake Oswego, OR
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2020 GLE 450; 2023 BMW M2 Coupe
Liked:1,264 Times in 912 Posts
Do you mean bigger wheels or tires? Those tires are actually the largest diameter of any of the OEM choices. You don't want to increase the OD of the tires any more than that. If you have the stock steel suspension vs. Airmatic the body does set a little high which results in more gap at the fender.Originally Posted by Wowmichaelwow
Hello guys. I have a 2020 GLE 350 with stock 20s. I want to install some bigger tires, as the current ones look small. Which size would fit perfectly without making so many adjustments? I was thinking about 21. Hopefully something not staggered, as the current ones are not staggered.I appreciate all the suggestions
Now if you want bigger wheels, yes you could go with 21s. The factory 21s are staggered, and the wider rears do look good and beefy; this is the simplest solution. You likely would have a hard time finding these as take-offs, though. Alternatively, you could go with 21x9 or 10s & 275/45 F&R, but the trick will be getting the right offsets, since they are different front and rear and most aftermarket wheels do not have a wide variety of offsets. I would suggest consulting a wheel specialist.
Thank you. I just want them to look more luxurious. I’ll wait until next year, after the winter season.
