Tool kit question
Old Feb 21, 2020 | 11:31 AM
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
Tool kit question
I have winter tires on rims from tirerack, which came with regular 17mm hexagon lug bolts, It just occurred to me that I won't be able to remove the winter lug bolts using the lug wrench in the toolkit. So I guess I need to order a lug wrench.
Also, are there special lug bolts for use with the spare tire, or do I need to keep 5 of the original Mercedes lug bolts from my original wheels?
My vehicle is a 450 that came with the 21" multispoke rims.
Old Feb 21, 2020 | 07:11 PM
Henry Stark's Avatar
GLC63S
Usually Tirerack includes an adapter with the lugs to fit your lug wrench if yours even came equipped with one depending if you have 3rd row. I ended up buying a Gorilla Automotive 1734DS off of Amazon. I also had to buy the jack kit from mb because min came with tire fit bs.
Old Feb 21, 2020 | 07:35 PM
tommyr's Avatar
I just went through the toolkit and found that it includes special lug bolts for the spare (they look like standard 17mm hex), and the lug wrench is hex as well. I test fitted the wrench and it does work with the Mercedes flower lug bolts.
I went with Henry's suggested lug wrench, it looks to offer better leverage. So I guess I was ok running with the tirerack winter setup, but I'm glad I double checked.
Old Feb 21, 2020 | 07:52 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Lug wrenches
Don't use the hex wrench on the "flower head" bolts. The thin cap will deform with just a few uses.
Flower head socket: https://mbworld.org/forums/gle-class...ml#post7976122
Old Feb 24, 2020 | 11:39 AM
tommyr's Avatar
Understood, thanks Greg. I find it odd that the Mercedes supplied lug wrench is hex vs flower. Perhaps they assumed most operators won't be using it??
