Rear Window Washer Fluid
Old Mar 21, 2020 | 12:29 PM
bogleric's Avatar
2020 GLE 350
My wife noticed a while back that the rear window was not spraying when pushing the wash button. I tried a few different time and it worked fine. Today, with all the fun pollen, I tried to use it and nothing. I repeated several times and even held for quite some time. I believe this shares one reservoir that handles both the front and back. At first I was wondering if the line essentially emptied back forward, but the pump shouldn't allow that.
Has anyone had similar issues? If not I will take it in, but if something simple I would rather save my time.
Old Mar 21, 2020 | 12:35 PM
chassis's Avatar
2017 GLE350 4MATIC
There are a couple of posts on this site related to the rear window washing system. Is there any reason to think you may be out of fluid?
Old Mar 21, 2020 | 12:42 PM
bogleric's Avatar
2020 GLE 350
Plenty of washer fluid... the reservoir is full and all three jets spray like theres not tomorrow.
I have seen some other posts, many of which were defect rants; however, if you know of a helpful one I will gladly check it out.
Old Mar 21, 2020 | 01:26 PM
jcapotos's Avatar
2025 Porsche Cayenne S Hybrid + 2023 EQS 580 SUV
i had a similar issue. Upon a recommendation from another member, I went and pushed the button with more pressure and it works fine.
Old Mar 21, 2020 | 08:52 PM
jbizios's Avatar
GLE 350, C300, GLC 300
My experience is a slight push..you get a wipe...a more heavier push you activate the jets...similar to the front single wipe push button on the stalk...but your "mileage" may vary. Good luck!
Old Mar 22, 2020 | 07:55 AM
bad habit's Avatar
A
If it doesn't work you better have it checked out another user here on the Forum had that issue and it turned out that the supply line was disconnected, causing fluid buildup somewhere else
Old Mar 23, 2020 | 10:05 AM
tiri's Avatar
2020 GLE450 4Matic AMG-Line
Here's a different take:
When running low on fluid, the rear spray will not function, only the front will as it is more critical for safety to have a clean windshield than rear glass. It also serves as an early low fluid level indicator prior to the lamp on the dash.
