Convenience opening not working
Old Jun 23, 2020 | 10:55 AM
bigpern23's Avatar
2020 GLE 450 AMG exterior
As the weather has finally warmed up, I'm finding that the convenience opening feature (press and hold unlock on the key fob to open windows and sunroof) is not working. Has anyone else run into this? I hate to have to take it into the dealership if it's something simple that I'm overlooking. The manual doesn't indicate that I'm missing any steps.
Old Jun 23, 2020 | 11:11 AM
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
Works for me. I unlock the car, then press and hold the unlock button; windows start dropping in a few seconds.
dthzo's Avatar
GLE 350de 2025
it’s infrared for the quick open / close command so you have to orient the key close enough to the driver door handle
Old Jun 23, 2020 | 11:19 AM
bigpern23's Avatar
That could be the issue. I was trying to do it from a fair distance away. I'll have to try doing it a little closer.
Old Jun 23, 2020 | 12:44 PM
Spitfire63's Avatar
E63S Wagon
I thought mine wasn't working, but then I realised that the first thing it does is to open the sunroof blind, and since this takes forever I was giving up on the whole "episode" before it made it as far as the windows. Just be patient ... it probably does work.
Old Jun 23, 2020 | 05:51 PM
Philamg's Avatar
GLC 450
I can open mine from inside the house, it doesn't have to be close to any door handle.
Old Jun 23, 2020 | 08:37 PM
bigpern23's Avatar
That's where I was trying to do it from.
Old Jun 23, 2020 | 08:38 PM
bigpern23's Avatar
I almost never close the sunblind, though I probably should when parked.
Old Jun 25, 2020 | 04:24 PM
tiri's Avatar
2020 GLE450 4Matic AMG-Line
I find I have to be within a few meters of the car for it to work.
Old Jun 25, 2020 | 06:24 PM
dthzo's Avatar
GLE 350de 2025
this is normal for infrared. you must be in direct view of the sensor in the driver's handle
Old Jun 26, 2020 | 06:40 AM
Philamg's Avatar
GLC 450
Sitting in my living room with 2 walls between me and the car and it is opening and closing the doors.
Old Jun 26, 2020 | 08:39 AM
Spitfire63's Avatar
E63S Wagon
Don't our remotes communicate with the car via RF rather than IR?
Old Jun 26, 2020 | 08:54 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
These remotes us UHF radio not IR
Old Jun 26, 2020 | 01:12 PM
Cbc200's Avatar
2020 GLE 350d AMG Line Prem+
I have to be within a few a few metres of the car to open/close the windows with the key fob.
Old Jun 26, 2020 | 05:27 PM
bigpern23's Avatar
Had a chance to test it and it doesn't work until I'm within two or three steps of the vehicle. Not ideal since they aren't really even down by the time I reach for the door handle.
Old Jun 26, 2020 | 10:21 PM
user 7208224's Avatar
2020 GLE 350
Is it possible that there is no allocated radio spectrum in the UK for this feature?
Old Jun 27, 2020 | 04:11 AM
Philamg's Avatar
GLC 450
I am in UK and works well from a distance on mine.
Old Jun 27, 2020 | 04:28 AM
Cbc200's Avatar
Just to confirm, you are talking about opening and closing the windows/roof from a distance and not just unlocking the doors?
Old Jun 27, 2020 | 07:10 AM
Philamg's Avatar
GLC 450
Opening closing windows/roof works from about 10 metres even with wall in between, car opens / locks at 50 metres+
Old Jun 27, 2020 | 10:18 AM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
But what he failed to mention is that he is also pushing the key up to his chin while wearing a tin foil hat. JK.
I’ve always had to be very close for this to work on any of my MBs.
Old Sep 19, 2021 | 01:28 PM
W205C43PFL's Avatar
Had this same issue, curious if there is anyone else other than Spitfire63 and me experiencing this. Basically I have to first hold the unlock button till the sunblind opens completely then when it stops, let go of the unlock button then hold the unlock button again for the windows and the sunroof to finally open. Anyway around this, other than keeping the sunblind open when parked in the sun?
As for the proximity issue, I have no such issue using this feature while pointing out from inside the house to the rear of the car in my garage.
I also always thought the proximity requirement is a safety feature (theft protection for example) but as long as I am within meters from the car it works for me (the sun blind still has to be opened though) so I am confused why is it like that.
Old Sep 19, 2021 | 06:45 PM
jaketuff's Avatar
ML 350
Definitely finicky... pointing at driver's door is a must to work. And you need to be reasonably close... 10 meters feels adequate.
