My Burmester stereo sounds awful
Can you get the MBUX system with the High End Burmester 3D system on the 2020 GLE? Seems like you have to remove the MBUX to add the High End Burmester system when configuring your car online.
MBUX is software running on those 2 screens, you cannot add it or remove it. There are options such as Augmented Reality navigation that can be added but MBUX itself is included by default.
#32
One question what is the source?
I have GLC350 with Burmester and use memory with MP3 320 bitrates. Sounds quality probably better vs my old ML 350 with KH Logic 7.
HD Radio or Satellite Radio cant get you all bitrates. If you want to hear real cool sound try to use DTS Audio disc.
#33
mikapen (01-05-2021)
bad habit (07-25-2020)
#35
Originally Posted by bad habit
If by Satellite Radio you mean XM, there is no quality there. I think the bitrate on XM is like 64 kbps and it sounds like *****.
My point was the source, if the source has quality audio system sound is perfect.
#38
100% Agree. My 2017 E class with Burmester sounds nothing like this. There is absolutely no clarity or detail in the EQ settings. Sounds as if something is covering the mid and tweeter. Watching Movies USB truly reveals how bad the sound is. Subs sound like there playing at 250hz imo should be at 150hz. Still doesn’t explain the lack of detail in door speakers unless these are just Standard COVID emergency speakers behind a Burmester grills. May add a 100Hz passive resistor to the 2 subs speaker lines to stop this muddy thumping. BTW none of the loaner GLC’s I’ve had sounded like this. Hopefully we have a burn in period on the drivers. 🙏🏾
Setting the Focus to Rear strangely improved the mono sound and leaving EQ at 1, -0-, 3 Suround On
Spotify HIFI & USB Flac Sources
Caseyb829 (12-17-2020)
#39
C63s Burmester upgraded with Helix Match UP7DSP/Amp
We have recently performed a Stage 1 upgrade to a 2016 C63s with the Burmester 9 speaker system. Essentially, we wanted more control, a bit more power, and "tuneability". The process was fairly straight forward and the results are pretty impressive.
Basically, we took the MOST150 signal from the Burmester Amp and re-routed it through a NAVTV Zen-M MOST Connector (https://www.audiotec-fischer.de/en/h...s/nav-tv-zen-m). From there we use the TOS-Link optical stereo output and connected it to the Helix Match UP7DSP/Amp. Then connect the 7 channels back into the OEM speaker loom (minus the rear surround speakers. Helix do a V TWELVE DSP/ 12 channel amp but its potentially over-kill unless you are doing some significant speaker upgrades)
From a power perspective, this is a little more than twice the power of the Burmester amplifier (which is 7 x 50w, plus 2 x 120w for the footwell woofers) compared to the UP7 (which is 5 x 75w RMS / 150w Max, plus 2 x 160w RMS / 320w Max for the footwell woofers).
From a DSP processing and control perspective, this is a brand new system. A much punchier, smoother bottom end, crisper less harsh mids, and a detailed top-end minus the ear-ache. It's pretty loud as well at around 100dB.
I did a lot of reading through these forums and can see that this may be a good option for those less than impressed with the Burmester (or other factory systems) upgrade.
Install time was about 4 hours and so far we have done two full tunes and about 2 hours each. Each time, improving our results.
Cheers. Ben
Cheers. Ben
#40
E63S Wagon
Cheers. Ben
Cheers. Ben
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Perhaps if you ever perform this mod on a GLE you might document the process?
EMEIVI (02-21-2021)
#42
I've found that what does have an impact on sound quality is the bit rate of the music I'm playing. A higher bit rate = more dynamic sound; and I can tell the difference. That's one of the reason I don't like XM, and I don't like to stream music over bluetooth -- they have lower bit rates. I use Spotify premium, and save my favorites to my iPhone using the highest bit rate. I also connect using the USB port, I've found that makes a big difference!
chassis (01-06-2021)
#43
Received 3,630 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
I don’t know if anyone noticed, but the High End Burmester 3D Sound System is no longer an option in the GLE for 2021. Doesn’t look like it is available in the GLS either. If it is standard in the ridiculous Maybach SUV, they say nothing about it on the MBUSA website.
#44
Received 1,606 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
As noted above. Most digital mediums compress the music in order to save storage or bandwidth space. They are actually cutting out parts of the music. If you want high quality sound, Spotify Premium, Tidal Music or CD player will give you the full dynamic range. HD radio is also better than a regular FM source. I listen to XM radio for sports and news only. Music on XM is substantially compressed and sounds terrible, its like listening to mono since there is not much stereo separation. iTunes or bluetooth over your phone is one of the worst ways to listen to music if you want high fidelity.
On the standard Burmester, to my ears, I can't really hear the difference between MP3 (compressed) or FLAC / CD (uncompressed). I definitely CAN tell the difference with the High End 3D Burmester.
I also find the "tone controls" to actually DO something on the 3D, where they just seem to move the dropouts (parts of the sound spectrum where there is no sound) around. It's like the base Burmester speakers are out of phase.
As far as listening goes, if you can hear the difference between codecs, you have a pretty fine car audio system. I'd put the High End 3D in that category.
#45
Trying to figure out how to turn off the speed compensated volume on my GLE450. I HATE THAT! Most cars allow you to adjust that volume compensation or turn it off completely. It is very annoying to have the volume of the radio change between slow and fast speed. Let me make the decision what the volume should be. Anyone know how to do that? I have tried all the settings, but have not found a way to turn off that "feature".
#46
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I’ve had the Burmester system in 3 MBs now- 2015 C Class, 2018 E Class (sounded best) and now the nicest car of all, my 2021 GLE. I can’t believe how poor this system sounds in the GLE. I really hope it gets better but it actually sounds like something is wrong with it. It’s so shallow and sounds like it’s only coming from the front. I’ve played with all of the settings.
EMEIVI (02-21-2021)
#47
pdugganbeck (08-28-2023)
#48
#49
I have the same issue, the sound is so flat on GLE450 4matic. I have driven only 500 miles. My friend has BMW X5 40i 2019 and the sound is incredible. I wish I could have checked it before leasing.
The following 3 users liked this post by Anwar Hamid:
#50
2023 GLE450, 2021 E350 / Used to drive: 2019 E300, 2021 + 2020 GLE350, 2019 E450 Wagon(s), 2017 E300
So - the odd thing is that I had an MBUX software update a few months back - and the "standard" Burmester seems to sound better after that. (Or I am just used to it now...)
EMEIVI (02-24-2021)
