My Burmester stereo sounds awful
I've cranked up the high and mid to +10, and I've put the bass to -3, and still there's too much bass and not enough "detail" in the highs and mids.
Am I the only person who feels this way? Does anybody know if a firmware update might fix this?
I've only got a few hundred miles on mine, but I'm already thinking through a solution.
I'm thinking that I am going to get a subwoofer amplifier with EQ. I know what what you're thinking, why amplify what's already too much....
If I get a sub amp that has a bunch of sub EQ, AND a remote level knob, I can dial in the amount of subwoofer level (different than the BASS + or - adjustment on the eq controls on settings of the radio) and adjust the EQ to tune the woofers properly.
Thinking I'll use this: http://www.wavtech-usa.com/linkq
With this Amp: https://www.rockfordfosgate.com/prod...ails/t500x1br/
Thoughts?
Thoughts?
Maybe I just like a bass-heavy system, I dunno.
If you listen to the Burmester High-End 3D system the difference is night and day. The version in my Porsche is sublime. It's hard to believe they are made by the same company.
The low-end Burmester system (I'm calling it low-end because I think it sounds quite crappy given the cost of the car) you won't have those additional speakers. It should be pretty obvious which Burmester you've got.
Thanks for the tip about bit rates in Spotify ... I'd never noticed that setting before now but I am now experimenting with it thanks to you.
