Wheels Question
Old Oct 3, 2020 | 09:01 AM
chrislk55's Avatar
2023 GLE63S - Edition 55
Wheels Question
Hello All,
I picked up my 2020 GLE450 last night ! I absolutely love the car. Sadly I had to say bye to my old ML350 Bluetec, she gave me 5 years of trouble free service.
The 450 is Obsidian Black with the night package, I'm not a fan of the standard 20" wheels, I feel they should be bigger on this vehicle.
I found a set of wheels from a 2019 GLE63 Coupe that I like, however my dealer tells methey won't fit. Apparently, the offset is off by 10mm on the front and 90mm on the rear. I'm not an expert on wheel offsets, is this truly the case? What is the impact of the different offsets?
Old Oct 3, 2020 | 09:47 AM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
The AMG wheels are also wider and the bolts might be 14mm vs 15mm on your new car. As I recall, the AMG are 10” front & 11” rear with a different tire front and rear. The wheel size is probably different maybe 21 vs 20 if you have the AMG body on your 450. You could drill the wheel for 15mm. There are online calculators to show the difference. My thought would be to actually try one to see if they fit. With a 14mm guide pin you might be able to slip one on to get a visual. You would also need to replace your tires with the larger wheel.
Check the Winter Tire thread for lots of fitment details.
Another option would be to buy aftermarket wheels that will work with your existing tire or get a larger AM wheel with new tires. Mandrus makes wheels specifically for Mercedes. Also Vossen and other premium wheels have options and dealers with fitment experience.
Old Oct 3, 2020 | 10:01 AM
chrislk55's Avatar
Thanks for the reply. I'm certainly not absolutely stuck on these wheels, a good aftermarket product would be fine, that was my next question .... I would welcome any suggestions on good aftermarket rims for the GLE450. I prefer the staggered look with wider wheels on the rear.
Old Oct 5, 2020 | 07:11 PM
HaydnM's Avatar
GLE400 W167
Check out the Vossen website
https://vossenwheels.com/
https://vossenwheels.com/vehicle-gal...des-benz%2Cgle
Great value for money & very good quality too
Old Oct 5, 2020 | 07:49 PM
chrislk55's Avatar
WOW !!!! Thank you very much ! I'm thinking the HR1 Tinted gloss black will go perfect with my Obsidian black / night package car !
Old Oct 8, 2020 | 07:48 PM
chrislk55's Avatar
I found these and I assume they can be ordered locally. They are 23" though, can anyone advise if they will fit on a 2020 GLE40?
https://mercteil.com/product/retrofi...-for-gls-class
Old Oct 8, 2020 | 10:42 PM
joejones81's Avatar
Awaiting a 2021 GLS580
UPDATE - for other forum members that may be interested, here is the link to the 22” GLE580 rims on the Mercteil site https://mercteil.com/product/retrofi...-for-gle-class
Keep in mind that there doesn’t seem to be any tire manufacturer that makes all-season or winter tires for the OEM GLS580 23” wheels.
Below are links and prices to purchase the 23” GLS580 rims and 22” GLE580 rims from a dealership in the US.
Old Oct 8, 2020 | 10:56 PM
chrislk55's Avatar
They have the 22" rims on their website also. They are very similar, I would go with the bigger option if it fits. I'm still trying to get an answer on that.
Old Oct 9, 2020 | 11:13 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
23" wheels/tires
Should fit as widths and offsets are same as OEM 22s. Difference will be the OD will be larger by an inch, which is quite a bit. RPMs on 23s would be about 3% slower than 22s.
Old Oct 9, 2020 | 12:50 PM
joejones81's Avatar
GregW, the widths and offsets are different between the 22” and 23” OEM rims. The 23” rims have widths of 9.5 and 11.5 and the 22” rims have widths of 10 and 11. The 23” have an offset of ET45 and ET47 and the 22” rims have an offset of ET56.1 and ET50.
Old Oct 9, 2020 | 01:07 PM
joejones81's Avatar
If you want you can go with slightly lower profile tires on the 23” wheels so that the total diameter of the tire is much closer to the total diameter of the 22” stock tire. See pic for comparison (23” typically come with 35 rear, not 30 rear).
https://www.tacomaworld.com/tirecalc...5r22-325-30r23
Old Oct 9, 2020 | 01:51 PM
Ducatisti's Avatar
'12 Ducati 1198S, GLE C292
Those wheels are the best looking on the GLE imo. Sadly it wasn't possible to order em when I ordered mine.. and its a $8200 upgrade on my 21" ..
Old Oct 9, 2020 | 04:18 PM
M4CES's Avatar
2018 Mercedes E220d Cabriolet
I got 10 x 23" on my GLE - they fit without any problems at all with 285/35r23 tyres
MORE PICS ON THIS LINK
Old Oct 9, 2020 | 04:59 PM
chrislk55's Avatar
That looks amazing. I have the exact same car, black with night package. Can you provide details about your wheels? Are they the same front and rear or staggered? What are the widths and offsets for front and rear? Did you require spacers? Thank you !
Old Oct 9, 2020 | 06:04 PM
M4CES's Avatar
10” x 23” same offset (don’t know it off the top of my head) front and back with a 30mm spacer on the back to fill the arch.
285/35r23 tyre all round too *edited tyre size
lowered on custom spring set up by approx 25mm
I’ll get offset tho from the paperwork 2moro
Old Oct 9, 2020 | 06:26 PM
threeMBs's Avatar
Only MBs - the best or nothing
275/35r23 tyre all round too
Any particular reason for not using 295/35R23?
Old Oct 10, 2020 | 03:34 AM
M4CES's Avatar
my mistake I am running 285/35R23 - this was the recommended tyre size to keep the rolling ratio as close to standard
Old Oct 14, 2020 | 07:51 PM
chrislk55's Avatar
I'm having a tough time figuring out my wheels delimma. I would like to go up to 21" or 22", however, from all the research I've done, it appears that anything over 20" requires a staggered setup with summer / winter tires. I hate the whole changing wheels back and forth so I was really hoping to stay with a good quality all-season tire. Any ideas or suggestions would be greatly appreciated.
Old Oct 14, 2020 | 08:28 PM
Ron.s's Avatar
Here are two sets for factory 21” setup from Tire Rack.
If you buy AM wheels with the same front and rear wheels then there are lots of choices in the 275/45 R21 10” front wheels. It’s the rear that are rare. These are H rated to 130MPH speed.
CROSSOVER/SUV TOURING ALL-SEASON
Category Ratings Charts
Compare
(169)
| Reviews (161)
Best Seller
Tire Rack Tested
CONTINENTAL
CROSSCONTACT LX SPORT
Crossover/SUV Touring All-Season
  • Front: 275/45R21 107H
  • MO Mercedes
  • Style: Blackwall
  • Serv. Desc: 107H
  • UTQG: 480 A A
  • Qty:
    Per Tire:
  • 2
    012345678
    $309.69
  • Availability: 1 In Stock, 10/21/20
  • Can be delivered Fri, 10/16 to 83704
    Free Shipping
  • Rear: 315/40R21 111H
  • MO Mercedes
  • Style: Blackwall
  • Serv. Desc: 111H
  • UTQG: 480 A A
  • Qty:
    Per Tire:
  • 2
    012345678
    $340.23
  • Availability: 4 In Stock, Special Order Available
    Free Shipping
Set of 4: $1,299.84
Free Road Hazard Protection
($125.88 value. Two-year coverage.)
Add to CartAs low as $79/mo with Affirm
Compare
(169)
| Reviews (161)
New
Tire Rack Tested
CONTINENTAL
  • Front: 275/45R21 110V XL
  • MO1 Mercedes
  • Style: Blackwall
  • Load Range: XL
  • Serv. Desc: 110V
  • UTQG: 480 A A
  • Qty:
    Per Tire:
  • 2
    012345678
    $320.32
    Free Shipping
  • Rear: 315/40R21 115V XL
  • MO1 Mercedes
  • Style: Blackwall
  • Load Range: XL
  • Serv. Desc: 115V
  • UTQG: 480 A A
  • Qty:
    Per Tire:
  • 2
    012345678
    $365.14
Old Oct 14, 2020 | 08:35 PM
chrislk55's Avatar
Thank you, that really helps !
Would you recommend getting the same 10" size all round similar to the setup I currently have? Not sure how well a 315 all season tire will perform in the winter months ?
Old Oct 14, 2020 | 08:40 PM
threeMBs's Avatar
Not sure what the dilemma is. It is actually very simple. From posted above, your 450 is equipped with square 20" wheels/tires. You want to go to 21" or 22". You do NOT need to go staggered, unless you want to. Staggering is NOT required. MB chose to equipped 21" and 22" option as staggered fitment. You can go 21" wheels with 275/45-21 or 285/45-21 at all four corners or 22" wheels with 285/40-22 at all four corners. All before mention tire sizes are available with good quality A/S tires, but not necessarily MO labeled tires.
Old Oct 14, 2020 | 09:02 PM
threeMBs's Avatar
A. not sure 315 will fit upfront, B. not sure it should be mounted on 10" wide wheel (10.5" minimum), C. and am positive that 315 will be an adventure in snow/ice you do not want.
Old Oct 14, 2020 | 09:08 PM
chrislk55's Avatar
Great info! Thank you! I'm thinking 275/45/21 all around will be perfect.
Old Oct 14, 2020 | 09:44 PM
Larger AS tires
Not true - the factory RW/RWB 21s are staggered but fitted with All Season tires (Pirelli Scorpion Zero A/S on mine). Not ideal for snow, but fine for less severe conditions.
Ron.s's Avatar
Those setups are the same as the factory size 275 45/21 for a 10” wheel front and 315/40/21 for the 11” rear wheel. That would mean no new wheels.
if you are going square front and rear then you could probably run 9” x 21” wheels. Most tires have a range for acceptable tire size...didn’t check the 275. My advice would be to work with a tire guy specializing in wheels. I think BB Wheels is one. ThIs forum has a section for vendors where they advertise and show pictures of lots of Premium wheels. The reason I say that is because there are nuances to fitment like larger brakes, wheel offset and the new for 2020 GLE 15 mm stud bolts. I’m waiting for my 53 to go much farther researching this to see if my existing wheels from my 2020 GLE will fit. I will get my 53 with the package that has the large brakes, even larger than the AMG on the 450, 580. It would be easy to overlook a fitment issue but the 450 has been out long enough to get some good Vendor info.
