Wheel locks
Old Nov 1, 2020 | 12:06 AM
Mcfancy14's Avatar
350 GLE 4matic
Wheel locks
I have the amg 21 inch multi spoke wheels (different widths between front and rear). Does anyone know the part number for OEM wheel locks?
Old Nov 1, 2020 | 08:16 AM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
I don’t but they are M15, Ball Seat and will either be silver or black depending on your wheels (night package?). The dealer will use your SN for fitment and they are about $150. I think all 2020-21’s use the same set and AFAIK there are no aftermarket available yet.
Old Nov 1, 2020 | 08:49 AM
Mcfancy14's Avatar
350 GLE 4matic
It seems these may be the silver ones “
A0009909819
does anyone have their box they came in to see the part number?
Old Nov 1, 2020 | 11:50 AM
maalox's Avatar
I believe those are the ones I have, I can double check next time I'm near the car (which may not be today).
FYI, I have the night package but still got the "silver" wheel locking bolts because the standard bolts are silver even with the black accent wheels. The black locking bolts would look off.
Also FYI, some online MB dealers sell them for ~$60 which is probably much less than your parts department does.
Old Nov 1, 2020 | 12:07 PM
Mcfancy14's Avatar
350 GLE 4matic
Yes. Mine is nite package with silver nuts so I’d need to do same and stay with silver locks as well. I’d be appreciative when you can confirm the part number
Old Nov 1, 2020 | 04:27 PM
maalox's Avatar
Yup, this is the case I have and a picture of my 21" wheels with black accents (night package) with the bolts.
Old Nov 1, 2020 | 06:36 PM
Mcfancy14's Avatar
350 GLE 4matic
Huge thanks
Old Nov 7, 2020 | 12:57 AM
Busa196's Avatar
2018 S63, lowered
It’s interesting to note that my wife has the exact same wheels on her 2020 GLE 450 and that the part number for the wheel locks are different- albeit the same wheel. Not to mention that her lugs came silver from the factory with the exception of the lock itself. We had the wheels powder coated solid black, but they’re the exact same wheels as above. I’m in the process of trying to buy black lugs which brought me to this post. Pics below for comparison.
Old Nov 7, 2020 | 05:18 AM
Ron.s's Avatar
I believe the Locks are Dealer installed so they gave you the wrong set initially.
Try Otis LA for Black Lugs, M15, 1.25, ball seat. As I recall they had them when I bought some conical last year.
Here are some on EBay-https://www.ebay.com/itm/20-Ball-Sea...-/153830778716
The bolt length on factory wheels is longer than on aftermarket so getting black the correct length might require some research. Aren’t factory bolts in black available now? The 22” come with black.
Old Nov 7, 2020 | 10:19 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Lug bolts / wheel locks
Stock length is 45mm, not the 28mm you linked to.
Old Nov 7, 2020 | 11:28 AM
Ron.s's Avatar
Correct probably too short but they are advertised for the 2020 GLE/GLS with so the question is how long do they need to be? I didn’t get around to measuring mine to see how long the bolt really needs to be for enough threads to be safe. (15mm of threads or is a little less thread still safe with the larger bolt?)
I saw a 1/2” spacer kit the other day with ball-seat bolts that were shorter than stock. Might have been Carid... Since there are factory bolts available that’s the best place to start, IMO.
Old Nov 7, 2020 | 12:07 PM
Lub Bolts
I did extensive measuring when I ordered my custom Ti bolts. I would not trust shorter than stock.
Old Nov 7, 2020 | 02:50 PM
threeMBs's Avatar
Only MBs - the best or nothing
Great picture, GregW. I found that arguing with some folks, who have no clue what they're talking about while continuing to put forth completely ludicrous information, is a waste of time.
Old Nov 7, 2020 | 04:00 PM
mikapen's Avatar
And then the temporary spare needs shorter bolts. Make sure you have the shorter bolts if you use your spare, otherwise the standard wheel bolts will interfere with wheel rotation.
Old Nov 7, 2020 | 04:17 PM
Ron.s's Avatar
Don't be so hard on yourself...no one expects you to be an expert on a car you don’t even own.
Old Nov 7, 2020 | 05:15 PM
mikapen's Avatar
Rule of thumb is that the amount of threads engaged, is at least the same as the diameter of the bolt. But not so long that they bottom out, or in this case, interfere with the wheel/disc rotation.
Old Nov 9, 2020 | 04:01 PM
Busa196's Avatar
2018 S63, lowered
That’s some awesome info! Thanks very much for that! 👍
Old Nov 9, 2020 | 05:31 PM
Lug bolts
Thanks - here's a CAD drawing I did:
Old Nov 11, 2020 | 10:47 AM
Mcfancy14's Avatar
350 GLE 4matic
Recvd my locks to day based on the tire package and lock spec noted above.....will confirm back later that they work properly
Old Nov 12, 2020 | 10:12 PM
Busa196's Avatar
2018 S63, lowered
So, not to hijack the thread but I’m still struggling to find black lugs for my 2020 GLE with the exact factory specs. After giving my local MB dealership my vin number they told me that I cant even buy them- they don’t make them in black. I find that odd because our GLE was sold to us with black locks, but silver lugs- pic below. Have any of you guys tried to find black lugs? Otis may have some that will work, but not quite the same spec, special order, no refunds and they’re 7.00/a piece.
I’m not sure, but I THINK these on EBay might actually work? http://www.ebay.com/itm/164378595855
I definitely appreciate all the insight here- thanks guys!
Old Nov 13, 2020 | 07:31 AM
Ron.s's Avatar
As I said before, the length will be the issue if you get M15x1.25 ball seat. If Greg’s drawing in post 18 showed the rotor depth you could calculate the necessary length to get something close to 15mm of thread in the hub using Greg’s calculations. Personally I would be OK with 12mm of thread...about 1/2”. The linked bolts don’t show a length so you might call them to get the measurements and ask about their return policy.
The Dealer running your vin is only checking for a factory bolt for your specific vehicle. Since no US built GLE’s have a wheel with black they will not find one even if it exists...that’s my understanding. There could be a black AMG wheel not offered in the US with black bolts that would fit....maybe someone in Europe will post. You could go to Germany to try a build and/or England to see what they offer. Like you said though...since they make black M15 locks they must make black bolts also. Another possibility is to check some of the performance cars like the Mercedes AMG Black to see if any come with black wheels & M15 bolts.
Old Nov 13, 2020 | 07:43 AM
threeMBs's Avatar
Paint silver caps. Easy, inexpensive, quick. I bought black (flat or gloss, your choice) auto touch up paint from Walmart for under $10. Start with four spare bolts. When paint cures, replace the four silver bolts, then paint the four you took out, so on.
Ron.s's Avatar
Just on a hunch I checked the G Wagon...2020 AMG G 63 and it has black wheels (21 & 22). Get a vin by searching inventory at some larger dealers and you may find your black bolts. You parts guy should be able to get specs after getting a part number.
Edit-Forgot the obvious...find a 2020-21 GLE with the 22” black wheels and you have your bolts. Get SN and check with your parts guy. Lots of AMG’s and some others. Maybe BACnmercedes has his SN, he has black 22’s coming on his 580👍
Old Nov 13, 2020 | 08:56 AM
DM335's Avatar
2024 GLS 450
My GLS 450 with 8-spoke wheels came in with locking lug nuts in black. It looked odd to have 4 silver and 1 black. My dealer ordered silver ones and replaced the black under warranty. If you look in the accessories available on the MBUSA website, you will find some info on black and silver locking lug nuts.
Old Nov 13, 2020 | 07:15 PM
mikapen's Avatar
Good idea BUT the spare lugs are a different length, probably too short for safe insertion/hold. If you try this, compare lengths first.
