Fuel door alignment?
Old Nov 2, 2020 | 02:02 PM
BigDonL's Avatar
10 C300, 2014 ML350, 2018 GLC300, 2020 GLE350, 2023 GLE53 AMG
Is it just me or are there a lot of GLE’s with fuel doors that don’t seem to close flush. I’ve looked a lot a lot of the pictures online, and GLE’s I’ve seen in the world. It seems like this is the norm. Is there any way to align the door so it closes flush? Or am I just being extra picky?
Old Nov 2, 2020 | 02:23 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Mine was flush...be Picky.
Old Nov 2, 2020 | 02:25 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Fuel door fit
Not picky - it should not look like that. Mine is perfectly flush. Dealer should correct.
Old Nov 2, 2020 | 02:41 PM
user 7208224's Avatar
2020 GLE 350
Mine use to be like that. They replaced it. It is still not perfect but not nearly as bad as it was. The replacement is a complete door and mechanism that will need to be painted. Seems like it should be a quick fix but it wasn't.
Old Nov 2, 2020 | 07:18 PM
petee1997's Avatar
...24 GLE53
Mine fits flush. That is unacceptable. No free pass on any new vehicle.
Old Nov 2, 2020 | 07:36 PM
Spitfire63's Avatar
E63S Wagon
Mine was EXACTLY like yours when I first collected my car, I couldn't believe how bad it was. I complained, my dealer agreed and ordered a new part (a gasket of some sort I think), but much to my amazement the fuel door "repaired itself" after a couple of weeks ... one day I noticed that it had miraculously become flush with the fender. I hope you have a similar happy outcome.
Old Nov 3, 2020 | 06:58 AM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
Mine isn't as bad as the picture, but it isn't perfect either. I am not bothered enough to have the dealer do anything - and I am not sure in my case that they don't break something else fixing it. BigDon - they definitely should fix that.
Old Nov 3, 2020 | 08:15 AM
chassis's Avatar
2017 GLE350 4MATIC
Doesn’t look right.
Old Nov 5, 2020 | 08:33 AM
places's Avatar
No more MB:(
Makes one wonder what the hell is going on with QC at Mercedes, specifically these newer GLE's. So many issues.
Old Mar 8, 2021 | 09:12 AM
Asturcon's Avatar
Gle 450 4matic chrysler 300c
Does it exist an official recall about the fuel door closing?
Old Mar 9, 2021 | 09:50 AM
Fuel door alignment issue
That would be a technical bulletin, not a recall, but haven't seen one.
Old Mar 9, 2021 | 01:45 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Do you have to type that in each time or have you set up an autoreply script?
Old Mar 9, 2021 | 02:13 PM
mikapen's Avatar
But, Even Trolls Love Rock N Roll....
Old Jun 22, 2021 | 11:11 AM
CMFUSA's Avatar
GLE350 (2021), 991.2 (2019)
I had the same problem ... and it also "fixed itself".
Turns out that if the fuel door sticks out like the first picture, then the rubber lanyard that secures the fuel cap, got stuck in between the fuel door inside and the top of the fuel cap. It's very tight and that pushes out the fuel door.
Once you move the rubber lanyard out of the way and around the fuel cap, the door closes flush (or at least a lot better).
That's what it was on mine.
Old Jun 22, 2021 | 03:12 PM
makris0000's Avatar
I am not sure if the photos I've taken of my GLE are deceiving me, but in some pictures it looks like it's sticking out like OP's and in some it looks like it's sitting flat. I'm going to check mine when I pick it up this week from the dealership (knock sensor being replaced).
Old Jun 22, 2021 | 03:13 PM
CMFUSA's Avatar
Check if it's just the cap's lanyard getting in the way. Good luck.
Old Jun 22, 2021 | 06:53 PM
zengshengliu's Avatar
2020 Mercedes GLE 450
I got mine replaced by the dealer. According to their note, one of the clip is broken which cause the mis-alignment.
Old Jun 23, 2021 | 11:48 AM
Daso's Avatar
2021 GLE 63
I had the same thing and they managed to make some adjustment before I drove off, but as others have mentioned, it seems to have gotten better after i had it and it is now fully flush. I did inspect 5 other GLE's at the dealer the day I picked up and they all had that slightly misaligned door. I'm not saying it's acceptable, but they managed to make it better before I left without replacing a part.
Old Jun 23, 2021 | 01:42 PM
jomama's Avatar
2021 GLS450
i have a 2021 GLS and noticed the same issue - the fuel door doesn't sit quite flush. i'm going to double check it when i get the car back from the detailer. it doesn't bother me enough to want it replaced (esp after i get the car paint corrected/ceramic coatedº but i wouldn't mind having it adjusted if possible.
Old Jun 26, 2021 | 03:37 PM
seehack's Avatar
2021 GLE450
CMFUSA is right. My 3/21 built 450 has the same issue. I checked and yes the lanyard is bend and it’s stuck between door and door hinge. Straighten it and place it away from the hinge, problem solved. Maybe that’s why some say it fixed itself over time. Thank you.
Old Jun 26, 2021 | 03:53 PM
CMFUSA's Avatar
Glad to be of service!
Old Jun 26, 2021 | 09:52 PM
PalmBeach2210's Avatar
2021 GLE 350
I had the the same issue and the dealer said they didn’t see anything wrong. I removed my fuel door and found that the clip that holds the door on the arm was bent to hell. I ended up buying some 3M double sided tape and trippled up the thickness and carefully reinstalled sliding it back on. Problem solved. I can’t believe I had to do something like this on a Mercedes.
Old Jun 27, 2021 | 11:09 AM
CMFUSA's Avatar
How did you remove the fuel door? Could you give me a brief description, please? I'd be interested to see how that is all help together.
Old Jun 27, 2021 | 02:34 PM
kvelez's Avatar
2021 GLE 450
Question Which Dealer gave you the runaround
Which dealer saw nothing wrong with it. Coggin or PB?
Old Aug 20, 2021 | 04:12 PM
Sigp232's Avatar
2021 GLE 450, 2017 GLC 300 4Matic, 2008 FJ Cruiser
Been humid lately in LA. So I’m blaming the humid since it swells everything up. Woke up this morning to go put gas and found gas door panel half sticking out. Used to be flush the last 4 months checked inside door panel nothing caught up.
