Charging battery on 2020 GLE 450
If I want to charge this battery, it is also connected to the AGM auxiliary battery. Can I place a trickle charger on the battery connectors under th hood in order to charge both batteries?
The dealer once again could not answer this question. There are 3 batteries in this car. The 48 volt lithium battery, AGM auxiliary and a small 12 volt battery that runs the start/stop feature.
Can anyone shed some light on this subject for me who owns one of these models?
Thanks again.
Toban
As far as I am aware, there is no way to charge up the 48v battery other than by running the engine - the DC/DC converter just does 48v to 12v, and not the other way around. That said, the 48v battery is quite limited in capacity, and the integrated starter generator kicks out a hell of a current when it's running - doesn't take very much running to fully charge it.
In short - the terminals under the hood / bonnet only charge up the 12v AGM battery. Everything else is charged only when the engine is running.
what might happen to the 48 volt battery if the car sits for say 2 months in a garage? Will the battery be dead when I return? I understand there is a standby mode you can put the car in to close off all electrical draws?
Your comments are once again appreciated as the dealer really doesn’t have an answer.
Toban
I think the key thing is to run the vehicle for 30 minutes or more at least once every two weeks, and it will be fine. They’re just not designed to sit doing nothing for months on end, but even if you did that, I believe the lithium battery would be just about OK for six months or so.
As they say. Your mileage may vary. The thoughts above are my best guess at what would happen.
