OEM Packages after build ?
Old Jan 13, 2021 | 11:47 PM
benzify's Avatar
Can we add OEM packages/options once the vehicle is delivered ? Say the “Exterior Lighting Package” ?
any other packages that don’t have to be part of the initial build ?
PS: please don’t say chrome sill/chrome door handles/wheel locks
Old Jan 14, 2021 | 01:17 AM
SEPicks's Avatar
2012 E350, 2020 GLS450
That depends if you are willing to pay for the options. Most options can be done, but will come at a much greater cost than doing it at the assembly line. So in your case for the "Exterior Lighting Package", if the package comes with different headlamps then you will have to pay for the two headlamps (not cheap) and the labors fees with it. From what I've seen on this forum, as long as you have the money you can get most of the options that you want.
Old Jan 14, 2021 | 07:47 AM
nsoltz's Avatar
2023 EQB300
I forgot to add the $150 metal door sill plate. Got ripped off to the tune of $475 by dealer to install one.
Old Jan 14, 2021 | 08:23 AM
tinman831's Avatar
2020 GLE
In general, any of the VPC installed items can be added after your purchase fairly easily. Any other options can still be done but at a much greater cost than had you optioned it from the get go.
Old Jan 14, 2021 | 09:53 AM
benzify's Avatar
IIRC @Ron.s did a DIY to add the door sill plate. not sure how much that ended up costing
Old Jan 14, 2021 | 10:02 AM
nsoltz's Avatar
2023 EQB300
Read about that DIY door sill plate. I figured it wasn't worth it since I was told I would be charged $175 for part plus minimal labor. Ended up at $475 including parts, labor and taxes. Simply too many other things to be concerned about now than a few hundred $$
