Dashcam features
Old Feb 22, 2021 | 09:19 PM
Timmay's Avatar
2021 GLE53 SUV
Dashcam features
My ordered GLE has the Dashcam option added, and the description on the website says it is a forward facing camera. My question - is this a separate camera over an above the existing surround ones already included, or is this something that makes use of them. Does anybody know if there is a button to push (something that can be assigned to a button) in case you need to quickly record an event?
I am debating whether or not to add a secondary rear-facing camera, or if there is an option to record from all four surround cameras simultaneously (or planned for a future update), similar to BMW.
Sorry if this has been answered elsewhere, I could not find it if it were. This is my first MB vehicle so still learning the features.
Old Feb 23, 2021 | 12:47 PM
JustBlessed's Avatar
2025 e450
Does every GLE come with a dash cam or was it an add on feature that needed to be added?
Old Feb 23, 2021 | 12:59 PM
Timmay's Avatar
2021 GLE53 SUV
This is an add-on item when ordering the car.
Old Feb 23, 2021 | 01:26 PM
Eaton's Avatar
Top Answer: 1
You launch the "app" in Mercedes me & Apps and start recordings there.
This is where the camera is:
Old Feb 23, 2021 | 01:33 PM
pcsgrp's Avatar
E350 4-Matic, GLE350, Harley Davidson Electra Glide
I have the camera when I come to a light. Is this option a software upgrade?
Old Feb 23, 2021 | 01:35 PM
Eaton's Avatar
Top Answer: 1
Nothing official has been announced, but coders are working on activation options if you do not have dashcam activated, but have the cameras/hardware to support it.
Old Feb 24, 2021 | 10:11 PM
Cchris osalag's Avatar
2021 GLE 450
I have the dash cam on my 2021. Not sure if the camera is a stand alone or used for other thjbgs but I can clearly see I have at least 3 cameras facing out from my windshield. I bought an adapter to plug into the vehicle to attach a jump drive. It is always recording when the vehicle is on.
Old Feb 25, 2021 | 11:17 AM
DavidBN's Avatar
2021 GLE450 / 2008 C300
Could you please ID/link to adaptor you purchased? And where did you plug it into?
Thanks.........David
Old Feb 26, 2021 | 12:16 PM
2021 GLE 450
I bought a jump drive and below is the adapter and location it needs to be inserted. Hope this helps
USB C to USB Adapter, Pack of 2, USB C Male to USB 3 Female Adapter Compatible with MacBook Pro After 2016, MacBook Air After 2018, Dell XPS and Other Type C or Thunderbolt 3 Devices, Gold
Amazon Amazon
Old Feb 26, 2021 | 09:36 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Why not just buy a USB C thumb drive? They are cheap and shorter than with the adapter....
Old Feb 26, 2021 | 11:24 PM
2021 GLE 450
Sure that would work also. I already had a bunch of thumb drives so was using what I had
Old Feb 27, 2021 | 08:18 AM
jtjbt20x's Avatar
2021 GLE450W4 SUV
This is what I use, but I usually put it in the center armrest USB-C port. This way it doesn't block the 12V power socket under the drive as shown here. I use it to record the dash cam and play music from it.
Old Feb 27, 2021 | 08:23 AM
jtjbt20x's Avatar
2021 GLE450W4 SUV
The part is
Amazon Amazon
Old Feb 27, 2021 | 12:23 PM
DavidBN's Avatar
Dashcam Memory Card
I'm not proclaiming to be an expert, but after watching this video:
this is the memory card setup I'm getting. Dashcams continually overwrite data which can wear out normal memory cards/thumb drives that aren't intended for such use. Any old thumbdrive/memory card will probably do, but pretty inexpensive to get what this guy says is the best.
128 GB is probably overkill (could record up to 96 hours before overwriting) but will probably be the least expensive upgrade in my new 450.
............David
