Hard wiring a CTEK 5.0 Charger under hood on 2021 GLE 450
Has anyone been able to hardwire the CTEK 5.0 charger to the posts under the hood? The positive post is under the red slide cover. Was wondering if there was some way of attaching the positive eyelet to that positive post and then find something nearby on the chassis to attach the negative eyelet? Then, where do you attach the charger itself? With the alligator clip on the positive post, it sticks up even when you attach the clip from the end.
Just thought had anyone permanently installed this charger using the eyelets so all one has to do is pull the plug out and plug it in rather than having to attach everything every time you want to charge? I found too I have to leave the hood open because it's tight. Right now, I'm just laying the charger next to the positive posts in the drain tray. I'm in a garage but you couldn't do this if it was outside and raining.
Any opinions on this?
Toban
There is a chance this winter we may fly down from Canada to our property. If that happens, the car would be sitting for 5 months in the garage. Need a charger then.
Toban
I wouldn't try to mount the charger itself under the hood - just the wiring. https://www.deltran-global.com/Ring-Terminal-Harness
