2021 GLE 53 AMG SUV Proper PSI (22 inch tires)
Thanks.
I am now running 41/36 with my 21's, and it's better handling than where I started 46/45 - rides better too. I'll keep trying lower over time, and don't expect to go back to the max until I start towing or put winter tires on.
And I may be wrong about the Snowflake on the gas flap meaning. But I didn't like that pressure. Unfortunately it doesn't look like I'll get any track time in this year (again) because of the virus, to dial in the handling pressures.
I have the Conti's.
Looking forward to more input from others.
I have the Conti's.
https://www.tires-easy.com/blog/moun...ke-symbol/?amp
Mercedes doesn’t have a 3 Peaks tire in our sizes yet so their mountain peaks refer to AS tires & possibly would include a 3 Peaks in the future.
I’ve observed as much as a 5 degree change in tire pressure & even 2 degrees higher on the sunny side. If you start low you could be running close to the higher number much of the time. That’s setting pressure in your garage without driving. A rule of thumb is to add 2 psi if you drive a short distance to fill the tire.
I’ve found that running Nitrogen on my 450 kept temperature variations closer but that was with 20” tires. Costco had a Nitrogen fill available for $8 a tire, might be higher now. I’m going to try Nitrogen again since it’s so inexpensive. The moisture in an air fill is partially responsible for wider temp fluctuations. Air Planes run Nitrogen (dry) because of the huge temp fluctuations in the air and on the ground. At best, we will only see a small benefit in most conditions.
The M+S "all season" connection needs to be expanded, though. M+S is a Rubber Manufacturers' Association standard, which only states the ratio of void to rubber on the road, of the tread pattern. It doesn't have any performance correlation except that more voids SHOULD work in snow better. Blizzak proved that to be wrong!
Here's this - https://auto.howstuffworks.com/tire-...esignation.htm
Mercedes does have MO Severe Service tires in 20 and 21" sizes. Nokian and Vredestein also have non MO of the correct sizes and ratings, and other tire manufacturers seem to have others in development. Pirelli has all the diameters covered if you can go with a non-MO tire.
And BTW I mis-stated in my earlier post - I am now running 39F / 33R in my 21's. Like it but still experimenting.
I would guess it has to do with preserving predictable handling characteristics, as much as tire loading.
Personally I would be OK with Speed H vs V since I don’t plan on driving over 100.
Pirelli has you covered in 20, 21, & 22", at speed rating W (168mph). Nokian & Vredestein in 20 & 21 V-rated. Some are MO, but that's less important to me than applications for my uses.
Choosing tires will become more difficult as time goes on, with the proliferation of sizes and shortage of raw materials. Lots of rubber and polymers going into PPE and gloves. Price increases, too.
The Michelin Cross Climates are the most likely to appear in the odd sizes that the AMG 53 uses - Michelin has gotten more aggressive now that Nokian has opened a new factory in the US and Goodyear bought Cooper. Cooper overstepped their Nokian US production agreement and started using Nokian compounding in Cooper tires. Then Goodyear bought Cooper, who had the Nokian chemistry. Bridgestone and Pirellii have also opened new factories in North America after the new NAFTA (USMCA) was accepted. Tire M&A's are stories in themselves!
0
