Stuck in 1st gear
Old May 12, 2021 | 02:08 PM
grivera116's Avatar
2020 MB GLE 350
Stuck in 1st gear
Hey All,
When I'm stopped and start to drive off the rpms shoot up as its stuck in 1st gear. Sometimes i have to manually shift up and sometimes it just catches itself. Really annoying, wondering if anyone else has this issue. I saw post about downshifting issues but none like my issue.
Old May 12, 2021 | 03:52 PM
mikapen's Avatar
Originally Posted by grivera116
Hey All,
Maybe your Accumulator valve isn't accumulating? Does it find a "false neutral" between gears? Full or part throttle?
Work on a good description so your Service Department has input to analyze.
Good luck.
I had that on a new W164, and it was dirt in the 3rd gear valve body, replaced under warranty at a few hundred miles. Lasted until we traded at 87,000 miles with lots of towing miles.
Old May 12, 2021 | 08:59 PM
grivera116's Avatar
2020 MB GLE 350
Hey Mikapen
No false neutrals
just revs high from stop position. At a stop then push a little heavy on the gas when im moving and the engine just revs high before hitting second. Even happens sometimes if im light on the gas.
will take it into the shop soon
thanks for the info
