Wheel Fitment Concerns
Old Jun 4, 2021 | 11:25 PM
Kurve's Avatar
C63
Hey everyone. I have tried researching this but I am having a hard time getting clear answers from wheel size guides. Would 2019 (previous generation) 21" GLE Coupe wheels fit a 2020 GLE? Sizes are as follows:
Front 21x10 ET 52 and rear 21x11 ET 38
Fitment can be more aggressive than stock would be. I just want to make sure these would bolt up on the car and wouldn't hit something or stick out a lot.
Thanks in advance!
Old Jun 5, 2021 | 08:38 AM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Thanks in advance!
You would probably need to drill the wheels for the larger 15 mm bolt on 20-21 models.
If you have the AMG body on the 2020 they should be OK.
For a fitment comparison plug in your numbers here:http://www.rimsntires.com/specspro.jsp
Old Jun 5, 2021 | 12:50 PM
Kurve's Avatar
C63
Thanks for the info! I had no idea that the bolts were slightly larger. Bummer
Old Jun 5, 2021 | 02:49 PM
Ron.s's Avatar
There is an old thread where Greg drilled his older M wheels. It doesn’t look like a big deal. I had a set of aftermarket wheels for winter tires-14mm that worked without drilling. I bought a drill bit but didn’t need to use it. With that small of a difference the drill bit should self center (by hand) if you take it slow and easy.
Old Jun 7, 2021 | 06:02 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Drilling wheels for larger lug bolts
Here is that post: https://mbworld.org/forums/gle-class...ml#post7784909
