Roof Racks
Old Mar 23, 2022 | 08:48 PM
hyperspeed's Avatar
GLE, R8, MYP
FYI if anyone is interested, my GLE got lemoned (MB buyback) so my Thule Aeroblade Edges are for sale.
1x Thule AeroBlade Edge 7504B XL
1x Thule AeroBlade Edge 7503B L
Locks are included too
Here's the listing in classified:
https://mbworld.org/forums/market/837724
Old Mar 23, 2022 | 09:00 PM
bluepane's Avatar
Mercedes-Benz GLE V167 300d
Hi all,
Thule release new product 720400 for GLE.
Below are the list for 2019+ GLE:
https://www.thule.com/zh-tw/roof-rac...25E6%25A1%25BF
Thule WingBar Edge system for your car:
Thule WingBar Edge 95 | 721420
Thule WingBar Edge 86 | 721320
Thule Raised Rail Edge | 720400
Old Mar 24, 2022 | 04:39 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Originally Posted by GregW / Oregon
The roof will not slide open will the OEM bars; it will pop up at the rear a small amount (~3/4" gap). The issue is the inside portion of the clamping mechanism of the front bar comes very close to the operable roof panel.
Same with aftermarket ones. On my aftermarket roof rack it can slide only 3-4" itches before it makes contact with the attachment.
Old Mar 25, 2022 | 06:47 AM
fm_carv's Avatar
GLE
So if you have a roof rack mounted you can’t open the sunroof? Did I understand it correctly?
Are the roof racks properly mounted?
Any videos out there showing this problem?
Old Mar 25, 2022 | 07:34 AM
jdhoang's Avatar
2021 GLE 450
Sunroof - no issue as glass slides inside. Panorama roof - open slightly w/aftermarket roof racks.
Roof racks properly mounted - manual states you cannot open panorama with roof racks.
Old Mar 25, 2022 | 08:35 AM
fm_carv's Avatar
GLE
So is this a design flaw on the GLE from MB?
Old Mar 25, 2022 | 09:53 AM
  #32
hyperspeed's Avatar
GLE, R8, MYP
mine with a sun roof was perfectly fine
Old Mar 25, 2022 | 10:33 AM
  #33
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Roof racks with Panorama roof
Not sure if you could call it a flaw, but sure seems like a design that allowed the roof to open would be possible.
Old Mar 26, 2022 | 05:52 AM
  #34
smvail50's Avatar
13, ML350, 15’ CLS 450,20’ Mercedes GLE450 AWD, 22’ GLE 450
My aftermarket cross bars do not allow for raising/ opening the pano roof fully. Just a crack before it contacts cross bar.
Its a compromise between lower profile and windage noises… vs roof glass panel use with loads on top.
Im ok with it as is…only use cross bars when roof loading required. Aftermarket cross bar quality and secure use very acceptable.
Old May 19, 2023 | 05:51 PM
  #35
wildta's Avatar
GLE 580
Just bought Inno (Japanese brand) carrier / cross bars and there's enough clearance for the panoramic sunroof to fully open, no matter the position of the crossbars along the rails. They are extremely easy to put on/off, less than 5min total. Downsides: they start to quietly whistle above 30MPH but I think this will go away with a load; they are rated for 165lbs which is decently less than OEM.
Here are the model #s that work:
  • XS100 aero base
  • XB108 42" aero bar
  • XB115 45" aero bar
I plan to keep them off and only use them when needed. I really appreciate the simplicity and ease of taking them on and off. I forgot to snap a pic of both on but here are some pics with just the front.
I've used the Inno surfboard rack for a decade so I know the longevity of the product is good.
Here's a video demo of the overhang model, the rail clamping is the same and gives you an idea of how fast it is to install and remove.
Old May 20, 2023 | 02:12 AM
  #36
  • XS100 aero base
https://youtu.be/rn8aXhq-Mi0
I would inspect that strapping once in a while if you will leave that rack up on your roof. That rubber will deteriorate overtime and might snap with load/pressure while the vehicle is moving. I would prefer the old fashioned rubberized "clamp" instead.
Old May 20, 2023 | 06:40 AM
  #37
wildta's Avatar
GLE 580
I only intend to mount the bars when needed otherwise they'll be sitting in a garage so they won't weather over time. The straps are stainless steel with a rubberized coating so I think it should be fine even if left on for years. It would be prudent to check on them though from time to time if leaving them on. With my Inno surfboard rack, it spent a decade on my previous vehicle on or nearby the salty air and plenty of UV without any rust to the metal parts or degradation to the rubber/plastic bits -- made in Japan probably helped the longevity of it.
Old May 20, 2023 | 02:09 PM
  #38
kvelez's Avatar
2021 GLE 450
Seems suitable for urban use. I'm a kayaker, and a much stronger Yakima was damaged by a strong northeasterly gust while I was going 65 MPH on the turnpike. Yakima replaced it but it was scary and dangerous getting off the highway.
Old May 20, 2023 | 11:41 PM
  #39
wildta's Avatar
GLE 580
Yes I wouldn't trust this with a kayak, rooftop cargo box would be fine though. I already have a Kuat hitch rack so no bikes on the roof for me.
Old Dec 23, 2023 | 11:59 PM
  #40
Mahi03's Avatar
GLE 350 4matic
Originally Posted by djer
Finally pulled the trigger on the Thule Evo Raised Rail and the Wingbar Evo 50" in black, will report once installed. The OEM one sits a bit too high and it's silver, I prefer black being it an AMG Night Package, you know. Will have either a roof basket or ski rack on them. Getting ready for Thanksgiving trip so gotta have these bars ready!
Were you able to confirm if the Thule evo wingbars allow the panoramic sunroof to open fully?
Old Dec 24, 2023 | 12:06 AM
  #41
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
I installed the Evo 135's and no, the roof won't slide back all the way. Wife's 9' paddle board fits great up there though.
Old Dec 24, 2023 | 12:09 AM
  #42
Mahi03's Avatar
GLE 350 4matic
Ahhhh, thanks for the feedback. How far back is the roof able to slide?
Old Dec 24, 2023 | 03:44 PM
  #43
jaxslk's Avatar
About 6 inches. Positioning of the rear Thule supports are what dictates how far back the roof opens. I aligned the Thule supports to the approximate factory mount / recommended positions.
Old Mar 2, 2024 | 05:44 AM
  #44
Philooe's Avatar
GLE 350 de , MY 2021
Yakima Aero Vs Thule Wingbar Edge
Hi, I need to buy crossbars for my GLE 350 MY `21. Does anyone have any recommendations on what to choose between Yakima Aero or Thule Wingbar Edge?
I really like the slim design of the Yakima model, that it is close to the roof.
To me it doesn't matter if not able to open the pano roof since will only use the crossbars during winter.
Any advice much appreciated
Old Mar 30, 2024 | 11:17 AM
  #45
Philooe's Avatar
Finally made a decision
Finally pulled the trigger on Thule Wingbar Edge black together with a Thule motion xt alpine roof box. Happy with my choice so far.
Old Mar 30, 2024 | 11:34 AM
  #46
wildta's Avatar
GLE 580
Looks good. Curious to hear what winter tires you are wearing and your opinion?
Old Mar 30, 2024 | 12:27 PM
  #47
Philooe's Avatar
Thanks! I have PIRELLI Scorpion Winter 275/50R20 109V MO (friction). Drive mostly in areas without snow, otherwise i would have chosen with spikes. But very happy so far. Got a good price.
