Offset question?
Old Sep 24, 2021 | 02:51 PM
sno's Avatar
sno
EQE 350+, EQS 450+, AMG C63
Offset question?
So I have been looking a some wheels, don't really like the ones we ordered. I found some but there is one thing... the offset.
The shop says that they will fit and are spec'ed for the 53 but I'm a doubting Thomas because when I look up the specs for 22's on the 53 the factory wheels are
56 FRONT
50 REAR
the ones I like are:
35 FRONT
30 REAR
These seem to push the wheel outward if I'm not mistaken. What do you guys think?
everything else about the wheels are the 10 in the front and 11 in rear.
Old Sep 24, 2021 | 06:47 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
That’s about an inch…they are already out a bunch. When I was shopping I couldn’t find a source that recommended anything that drastic. It might hit on bumps or turning I would think. I run et45’s on 8 1/2”-20’s on my winter setup. Here’s a calculator that might help-http://www.rimsntires.com/specspro.jsp
Old Sep 24, 2021 | 07:41 PM
HotRodW's Avatar
2021 GLE450
Normally an extra 20mm of "poke" wouldn't be an issue, but the stock setup is already pretty aggressive. I don't think I would do it myself. That said, I'd love to see it, so if you do it, please post pics.
Old Sep 25, 2021 | 10:15 AM
sno's Avatar
sno
Thanks guys yea when I did the calculation it was like .9 outward which is a lot. I'm not looking to change how much they peek I think where its at is perfect. I guess I will keep searching LOL not an easy task.
Old Sep 25, 2021 | 10:50 AM
Ron.s's Avatar
A year ago I went through the same process of looking for 22” aftermarket that would fit. As I recall, Discount Tire listed only one set. Tire Rack none; CARiD showed a couple but they were discontinued or unavailable. Then I checked TSW & Mandrus. IMO you are pretty much left with special order Vossens.
Old Sep 28, 2021 | 10:47 PM
Tigerpr1976's Avatar
2021 Mercedes GLE 350
Offset
I had the same issue. There just is not a lot of options in 22” especially since Mercedes has those rando offsets.
I ended up with a set of 22s with 38mm offsets all the way around. Can barely tell the difference from factory as far as look or how it drives.
Main difference is because I went from 275/50R20 tires to 285/40r22, so slightly less sidewall. That slightly changed the way it feels but nothing crazy.
Old Sep 29, 2021 | 12:44 PM
threeMBs's Avatar
Only MBs - the best or nothing
Actually the sidewall difference is exactly 1". Obviously the most noticeable difference (other than visual) is that with much (1" is much) lower sidewall the handling should improve very noticeably. There is also some ride penalty for sure, but 285/40 is not a low profile tire at all, so ride should still be quit comfortable.
Old Sep 29, 2021 | 07:35 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
56 FRONT
50 REAR
35 FRONT
30 REAR
It’s important to note if you are comparing the same width wheels. .Use the tool Ron.s posted if you have not already.
