Battery charge
Old Oct 6, 2021 | 08:10 AM
dpallone's Avatar
2020 GLE350, 2019 E450 Wagon, 2018 E400 Cabriolet
Battery charge
I have a 2020 GLE350 with 15K miles. It was valet parked at a hotel last night and I received a message at 1:15AM from Mercedes me connect the battery needed a charge and drive at least 30 miles. I called the valet parking and they said the car was turned off. Any ideas on the cause ?
Old Oct 6, 2021 | 12:56 PM
mikapen's Avatar
Low battery. After a lot of short trips, the state of charge decreases if you don't drive it "at least 30 miles" from time to time. You'll prolong the battery life if you occasionally integrate longer drives into your routes.
The car is always in some state of alert, waiting for the App to find it, communicate with it, or looking for over the air updates. It's not like the old days.
We saw that warning fairly regularly on our GLC300, which during COVID hadn't been exercised much. It took a couple of weeks, taking the Long Way Home, to get rid of the warning for good.
Old Oct 6, 2021 | 06:28 PM
user 7208224's Avatar
2020 GLE 350
I was getting that notification in the app quite frequently. I would charge the battery and it would be good for about a week until it happened again. With that alarm notification standing, I could not remote start the vehicle. The dealer ran a load test on the battery, and it failed. They replaced the battery under warranty.
Old Oct 10, 2021 | 04:13 AM
Alan Sammut's Avatar
Glc 250d 4Matic
charging vs recond
Mine is very very often showing PARTIALLY CHARGED even a couple of days after recharging with the CTEK MXS5.0. I was thinking of using the RECOND function of this charger. Anyone has feedback on this? I believe the original car battery at 43000km might be approaching replacement. So may be reconditioning battery via the CTEK charger gives a new lease before replacement.
Old Oct 10, 2021 | 02:27 PM
2020 GLE 350
I had the same problem and used the same charger. After the dealer did a load test, they replaced the battery under warranty. I had owned the vehicle for probably 18 months at that point.
