Exterior Lights
Old Oct 16, 2021 | 11:33 AM
Imanone's Avatar
2022 GLE 450, 2024 Volvo XC 60
Exterior Lights
Just picked up 2022 450. DRL working, but logo projector and side view mirror lights not working when doors open. Locator light setting is enabled. Anyone have this issue?
Old Oct 16, 2021 | 01:44 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
You say the locator lights are enabled. Are you referring to in the app? Has the app synced with your vehicle yet? My '21 450 locator lights work just fine.
Old Oct 16, 2021 | 01:48 PM
Imanone's Avatar
Did not see anything about logo lights in the app which has synced with the suv.. I found a light grouping in the infotainment screen and there was an option to enable locator lights. The visual on the screen shows mirror and pavement lights. Have I missed something? My wife has 2020 E350 and they work perfectly.
Old Oct 16, 2021 | 02:42 PM
MBguy013's Avatar
2021 GLC 300 4Matic
Sounds like you're in the right area. I think mine had an issue shortly after I picked it up but have worked ever since. I'm not sure if they were off in the app when it synced with the vehicle but I just checked and both the app and vehicle settings are enabled.
Old Oct 16, 2021 | 02:43 PM
Imanone's Avatar
Where is the setting in the app? You’re referencing Mercedes ME Connect, right?
Old Oct 16, 2021 | 03:11 PM
W205C43PFL's Avatar
Not sure if you tried this yet, but did you turn them all off and turn it back on again? It solved the issue of the mirror not folding for example by turning off fold when locked and then turning it back on. Electronics glitches now and then.
Old Oct 16, 2021 | 03:21 PM
Imanone's Avatar
I may be wrong, but I’m thinking they did not install the logo projector. If I open the driver door, there is a red reflector and a white light that seems to shine on the ground, but no logo. I think there’s also supposed to be a light shining from the side mirrors. Nada. I can’t imagine they deleted the logo projectors as they don’t have anything to do with the chip shortage. It also shows up on the window sticker under standard options. They did delete the AR.
Old Oct 16, 2021 | 03:30 PM
W205C43PFL's Avatar
Hmmm, I am unaware of them removing the light from the side mirrors for MY22 however they did remove all the exterior door handle lights since MY21. If the logo projectors shows up on your VIN data card then they should install it for you.
Old Oct 16, 2021 | 04:22 PM
Imanone's Avatar
I am almost certain that they just forgot to add them or for all I know, they didn't have them. I know that the dealers normally have these in stock, but we will see. I'll check with the dealer Monday. Hope I don't get a runaround.
Old Oct 16, 2021 | 07:28 PM
W205C43PFL's Avatar
Yup that must be the case : ) , they shouldn't have an excuse to not install them for you if it is part of your build and they didn't refund it (delete it from the build).
Old Oct 16, 2021 | 10:41 PM
Imanone's Avatar
I agree, but who knows these days?
Old Oct 16, 2021 | 10:50 PM
W205C43PFL's Avatar
I am just hoping nothing is on backorder and that they get it installed the same day you bring the vehicle in.
Old Oct 18, 2021 | 10:08 AM
Imanone's Avatar
On my wife's 2020 E350, the projector logo light is under the door panel and on my 22 450, it was only a light. Does your light come from underneath the door?
Old Oct 18, 2021 | 03:22 PM
Imanone's Avatar
So here is what appears to be the case. As I wrote, the logo light emanates from the bottom of the front doors on my wife's e350. Went to the dealer this morning and he said there was no logo projector at the bottom of the doors. He was a bit surprised. He then put a cover over the sensors in the front windshield and lo and behold, there was a logo emanating from the side view mirror. Same for the passenger side. It was too light in the shop staging area to see the logo on the ground, but it was clearly evident on his hand. I then looked at the build sheet for the car and it clearly says LED Side Mirror Logo Projectors. I never for one moment realized it was different on this vehicle and frankly, I'm quite embarrassed about the trip to the dealer and this thread. Mea Culpa. What a waste of my time and that of the gracious people who attempted to help. Thanks for your interest in my 'non problem".
Old Oct 18, 2021 | 09:07 PM
W205C43PFL's Avatar
Glad it is all sorted out now. It is not your fault honestly because it is an option available for both the mirror and under the door. It is natural for you to think when "projector light" is mentioned, it is just the under the door ones, as you experienced it on the E350. You would never had guessed there were two types and it is totally normal you think that way. In fact, on MBUSA's site, it only shows one option, which is the one under the front doors. There is no option for MB star projector under side mirrors.
Old Oct 18, 2021 | 10:53 PM
Imanone's Avatar
Thanks for the note. You are too kind!
Old Oct 18, 2021 | 11:16 PM
W205C43PFL's Avatar
Just speaking the truth : ) but I still have no clue why the MBUSA build site doesn't have the side mirror projector light as an option but it is definitely available when you order the vehicle from the dealership, perhaps. That is probably why it got confusing. Not your fault at all : )
Old Oct 19, 2021 | 08:21 AM
Neurobit's Avatar
2021 GLE 53 AMG Coupe
Glad you got it sorted out!
Old Oct 19, 2021 | 08:49 AM
Imanone's Avatar
Thanks. First world non-problem. Jeez, I guess I was a bit too excited getting a new car and I failed to read the build sheet.
Old Oct 19, 2021 | 08:52 AM
Neurobit's Avatar
No worries. A valid concern. I’d asked about this as well had I been in your shoes. Drives my wife crazy LOL.
Cheers,
Old Aug 3, 2022 | 06:25 PM
DREKNOWSBENZ's Avatar
CLA 35 AMG 4matic 2022
No sideview puddle light in cla 35 2022?
Got 2022 and it does show the option turn off mirror sideview lights on off but there are none does that mean the connection is there because I own some that should work and fit as they where custom puddle light I'd like install but need find vendor bottom cap with light hole. I'm 80% confident the connection is inside there otherwise why would I have option turn out off and on it does nothing on my car I've checked. Anyone else know anything? I'll update oh here is my ride
