Changing Engine Air Filter
#1- I drive in a dusty work area daily and over the years, I've learned that the air filter needs changing often.
#2- I've searched and found the description of a few, but not the new 4 cylinder.
Maintenance on your vehicle is like taking a bath or brushing your teeth, not sure it hurts to do it more often than recommended.
I have not changed the air filter yet but did remove the intake pipe from the air cleaner box to the throttle body for better access to the oil filter housing. It uses the typical ring clips that MB has used for years, just do not pull them all the way out to disengage. The filter housing looks to have the T20 fasteners on the upper side and maybe finger clips on the lower side. Again I did not go into the filter housing yet but looks fairly easy.
Please try this link.
Not very easy, but not very hard.
