Adaptive Headlights Coming?
SEC. 24212. HEADLAMPS.
(a) Definitions. — In this section:
(1) Adaptive driving beam headlamp. — The term “adaptive driving beam headlamp’’ means a headlamp (as defined in Standard 108) that meets the performance requirements specified in SAE International Standard J3069, published on June 30, 2016.
(2) Standard 108. — The term “Standard 108'’ means Federal Motor Vehicle Safety Standard Number 108, contained in section 571.108 of title 49, Code of Federal Regulations (as in effect on the date of enactment of this Act).
(b) Rulemaking. — Not later than 2 years after the date of enactment of this Act, the Secretary shall issue a final rule amending Standard 108 —
(1) to include performance-based standards for vehicle headlamp systems —
(A) to ensure that headlights are correctly aimed on the road; and
(B) requiring those systems to be tested on-vehicle to account for headlight height and lighting performance; and
(2) to allow for the use on vehicles of adaptive driving beam headlamp systems.
I'd guess that there would be a significant savings by not having to meet US standards, as I think we're the only market that has our ancient headlight rules.
This is where the cornering light is missing in the North American models:
I read somewhere that the cornering light is mounted "too high" for the GLE while perfectly fine on say the A-class or C-class. Surprisingly, it wasn't too high on my parent's X3 (G01, 2018-up) either. Previous generations had their cornering lights enabled by the fog lights which are mounted way lower, but more recently auto manufacturers (european ones especially) combined it as part of the headlight assembly.
The X3 G01 has both fog lights AND cornering lights, and they all can turn on simultaneously, and that's not even the top-of-the-line optional headlight feature. See diagram below.
And the fog light in addition to the headlight:
One is at high speed, where the main beam moves from left to right, or for those with multibeam LED, with additional LED activated that aimed at the corner.
On low speed or near roundabout, the main beam doesn't move (or activate additional LEDs), but instead, an additional light (the one you point out a few post ago where the "filler" is) activate, which is aimed at near 90 degree angles.
Personally, after having the car for 2 years, I don't think both is active in US. I do have the "activator" for the adaptive high beam enabled, but I don't think I ever see the high speed cornering light being activated (we definitely don't have the low speed one)
On mine, the high speed works on low beam only. It is subtle.
Will turning on the fog lights serve that function?
I know it's another step, but I hear you about driveways with drop offs.
"Adaptive headlights finally legal in US with Biden's infrastructure bill signed into law"
Who knows - the Sealed Beam Headlight Lobby may be more powerful than we expect. I hope not, but history might intervene.
