Tire Repair Kits
Tire Repair Kits
My car didn’t come with a spare. Instead it came with a tire kit that uses an internal spray foam and 12 volt compressor. However, I hate those fix-a-flat in a can.
My friend told me about using a real tire fix kit that most tire shops use. After doing some research, there’s not much too it and it can be done on the road. I just need to buy a jack and keep this kit in my car. Does anyone know if MB sells an OEM jack that will fit in what’s left of the spare tire well with a high-end Burmester?
ORCISH 70Pcs Tire Repair Kit, Heavy Duty Tire Plug Kit Flat Tire Repair Kit Tire Patch Kits Puncture Repair Kit (70pcs)
https://youtu.be/nCwWPlaghfs
https://youtu.be/6ODBx-HM-Ik
Received 1,606 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
https://www.amazon.com/dp/B07Y2X9MR3...CQR5E0JC5FQV1T
I'm not a fan of reamers, though, and I use a different plug kit called Dynaplug, adding pliers and a cheap combination screwdriver.
Dynaplug Tubeless Tire Repair Tool Kit - PRO Aluminum - Made in USA https://a.co/d/9Q5uFKc
As you can see from your videos, it takes some muscle to get the plugs installed. An advantage of the Dynaplug is that you can wet the tire with spit, which makes insertion fairly easy.Lighter and smaller, too.
Frenetic (07-27-2022)
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
Jack fitment
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x532/2019_04_29_07_8da3a750b3423c6b800a767f6e043a68973acb2d.jpg)
Our Michelin Rep advised against reaming, because of further damage to the belts. That was a long time ago (last Century!) and things may have changed, but I still adhere.
Also notice how hard it was to insert.
I'll give another Dynaplug "Plug," since it helps with both issues.
Don't forget the pliers.
(Wow, plugged "hundreds of tires!" I'm glad I don't drive where he does!)
