Coolant Flush
Old Sep 24, 2022 | 01:55 PM
GLE1673's Avatar
2020 GLE 350 NY
Coolant Flush
Just got a check coolant level message. How long do I have to add more coolant from the time of the message? Won't be able to do for a few weeks. Also, should I do a flush or add more coolant?
Old Sep 24, 2022 | 03:07 PM
GLE1673's Avatar
2020 GLE 350 NY
Also, does anyone know the part number for the coolant so that I can order. Thanks
Old Sep 24, 2022 | 07:37 PM
mikapen's Avatar
You shouldn't have to flush your system if you just adding a bit of coolant.
Here is a supplier of OE Mercedes coolant. https://www.autohausaz.com/pn/MB-Q1030005
I think that's the correct spec for all new Mercedes, and I think it supersedes and is backward compatible for older specs. DO NOT quote me on that - check the vendor's specs further down and verify that you're comfortable.
Old Sep 24, 2022 | 08:03 PM
GLE1673's Avatar
2020 GLE 350 NY
first picture is my coolant level with the white line. Can i just top off if that low?
Also second is the antifreeze MBparts says is compatible. The one you provided appears to not be one of the part numbers cited as a superseding part order.
Old Sep 25, 2022 | 12:22 PM
mikapen's Avatar
If you provided your VIN on that website, it's probably correct.
Since there seems to be a few options (Xerex is another aftermarket supplier, not OE) I'd ask my dealer, who will look it up by your VIN.
I probably go to the dealer to buy the correct stuff.
For that matter, since I don't have any way to dispose of 5 gallons of coolant (it's toxic), I'd just have the dealer do it.
Is there a special way to burp the system?
Edit: check your owner's manual for the correct reference point on the overflow reservoir. Check when cold, and use that reference point.
