3rd Brake Light wire
Old Apr 9, 2023 | 01:44 AM
gcam77's Avatar
2025 GLE 53 AMG Coupe
I am looking to power a center brake light in my diffuser and would appreciate any help with info on where in the passenger compartment I might find the wire that powers the brake light that is above the rear windscreen.
I can’t do it from the left and right taillights as they are coupled with the indicator.
Any help would be greatly appreciated.
Old Apr 10, 2023 | 02:24 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Post a picture of what you are trying to achieve.
Old Apr 10, 2023 | 10:37 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Diffuser (under bumper) or spoiler (roof)? Do you have the trailer hitch?
Old Apr 10, 2023 | 10:44 AM
mikapen's Avatar
That was my thought also. The 7 pin has a brake light signal.
Old Apr 10, 2023 | 11:10 AM
Although, brake and turn are combined, so not sure how that would work.
Old Apr 10, 2023 | 03:21 PM
gcam77's Avatar
I am looking to power the light in the diffuser.
The trailer hitch was my first thought but found out that they are a bit more intelligent than earlier models (ML) where in current models the signals are only present after a trailer is connected and detected by the vehicle and also certain features like, parking sensors, etc. are disabled. That's a bit too much, all I am looking to do is power the light in the diffuser. For US model 167s it seems like the 3rd brake lamp is the only place where an isolated signal occurs only when the brake pedal is pressed.
I was just hoping to find out the routing of the wire to the 3rd brake light in the cabin of the car so as to tap into it and avoid accessing it from the hatch and dealing with hinges and routing it back to the rear bumper.
Old Apr 12, 2023 | 10:57 AM
mikapen's Avatar
Would this or a comparable product work?
https://www.etrailer.com/Hitch-Cover.../CR-007XL.html
Edit 1: There are many more stylish offerings on the web.
Edit 2: The comment that the newer brake/turn signal circuits not responding when tapped into, is correct when running LED bulbs.
The car needs to see a load in order to recognize the device. LED bulbs don't provide enough load, so no current flows
Two probable solutions of you want to use the 7 pin source.. First, introduce a resistor into th circuit to provide the needed load.
OR use a device that has incandescent bulbs.
Old May 15, 2023 | 01:34 PM
wildta's Avatar
GLE 580
This detailed video of a trailer hitch getting installed in a GLE might give you some hints on where to wire in that 3rd brake light.
