E-Active suspension with Road Surface Scan finally working!
Old May 6, 2023 | 06:03 PM
MB_downunder's Avatar
2013 SL350 (R231), 2024 EQE350 4matic SUV (X294)
Originally Posted by wildta
My build date is 2020-01-19.
Here are various pics of my cameras if anyone is curious. I took close-up pics to see if my lenses were clouded but they appear clean to me. Just to note, the camera shrouds are black but my flash really distorts the color. Also, any idea what the little circle is below the stereo cameras?
Also, sorry Greg and maalox regarding your E-ABC situations. I would be in a fit with my dealer.
What is the circle sensor?
Your cameras are super clean! Don’t think you had any issues with the heater pad/off gassing from the camera lens hoods. The small circle is the rain sensor for automatic wipers.
Old May 6, 2023 | 07:11 PM
maalox's Avatar
I think I have some egg on my face, as it appears I do have the stereo camera setup, though I'm convinced the Road Surface Scan feature isn't working as designed. I feel every single pothole and speedbump quite strongly (and must slow down for speed bumps), and I certainly don't feel the suspension adjusting itself ahead of time. I'll ask about it next time I take it in, though I suspect I'll get the usual "working as designed" since I guess it's difficult to quantify "comfort" and there are no errors displayed to me.
I initially was looking at the pictures on my phone with some glare, and misunderstood what dual cameras everyone was talking about and what was blanked out. Here's a picture of mine.
I thought it was the circular one in wildta's post #25 circled in red in the first image, as it appears asymmetrical (i.e. its seems there "should" be a second circular camera on the other side, below the 2 triangular sections with the stereo cameras).
Old May 6, 2023 | 08:09 PM
wildta's Avatar
GLE 580
I'm with you, I can't tell if it's working as it should. Going over speed bumps and other bumpy roads in Comfort, I can't discern a difference vs Eco where it's deactivated. The curve, I can feel it working.
Old May 6, 2023 | 08:32 PM
Streamliner's Avatar
Boy, I feel for you guys who paid that gigantic option price for EABC in your GLE’s, only to have it not perform what is arguably “THE” most important function of the whole system.
I have the $6,500.00 EABC option on my 2022 S580 sedan. It worked over speed bumps for maybe four months, then stopped. Took it to Fletcher Jones, the largest MB dealer in the country and they proclaimed the system to be “functioning as designed.” It still did not handle speed bumps. A few months later, I got the camera malfunctioning message. Took it in again and they went through the cleaning of the “fogged” inner windshield surface. The message went away, but the system still does not make speed bumps “disappear,” like it did when the car was new.
Prior to my current S Class, I had three S Class sedans, 2015,18 & 20 with Magic Body Control, or MBC, which was basically the earlier Active Body Control or ABC, but with the addition of a camera to scan the road surface. The MBC system worked over speed bumps about half the time, probably because the camera just wasn’t sensitive enough. However, the ride quality of the older MBC was WAY better than my current EABC car—INCREDIBLY BETTER!
My feeling is that as of late, MB has been bringing technology to market way before it has been thoroughly and properly sorted. These hugely expensive options and they end up being nothing but trouble. I guess with the SUV’s they just threw in the towel with EABC. Sure wish they had just continued with the tried & reasonably true MBC in the new S Class models. Why they never put MBC in the GLE’s or GLS’s is a mystery. Oh well.
Old May 7, 2023 | 12:07 PM
mikapen's Avatar
The reason - Magic Body Control used belt driven pumps, and E-ABC uses direct acting electric motors. Quicker response, more granular control, more powerful, smarter.
Old May 7, 2023 | 12:31 PM
I understand and that’s all well & good, but if the “new & improved” system doesn’t deliver the goods, what use is it?
Old May 8, 2023 | 11:47 AM
  #32
mikapen's Avatar
Mine "Delivered the Goods," and was Stellar.
I had plenty of problems with my '20, camera and sensor related (I guess) but the suspension did "as advertised," and I could charge dips and bumps with impunity.
As a side note, AMG Ride Control does better on one-sided potholes than the E-ABC, but E-ABC handles full-width speed dips and RR crossings better.
(My '20 450, very loaded at $93,800, was returned. I miss it.)
Old May 8, 2023 | 12:03 PM
  #33
wildta's Avatar
GLE 580
What size rims did you have on your 450?
Old May 8, 2023 | 02:00 PM
  #34
mikapen's Avatar
20" Coopers.
Old May 8, 2023 | 04:24 PM
  #35
wildta's Avatar
GLE 580
20" Coopers.
I think that's my problem. 22s just don't cut it for comfort even with e-abc.
Old May 8, 2023 | 08:12 PM
  #36
djer's Avatar
GLE350(V167) C300(W204)
Proooobably the rain sensor? Try splashing water on that part and see if the wiper goes on.
Old May 8, 2023 | 08:17 PM
  #37
maalox's Avatar
I have 21", the sidewall and outer diameter between those and the 20" are pretty similar IIRC, and I'm still convinced I'm not getting any road surface scan benefits.
