2024 GLE 350 - Tyre Size Selection
#51
BenMB GLE450 (07-06-2024)
#52
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
So I just got my tires replaced… can someone check their staggered figment? I always thought the back tires were supposed to be wider than the front and it was quite obvious when looking strictly from the side. Ie. the stance of the rear tires are supposed to pop out a little bit from the side.
currently how it’s installed doesn’t seem to have that fitment? Can someone correct me if I’m wrong?
#53
21" amg vesion so front ones are 275/45R21 and rears are 315/40R21. went to the dealership to get them done and checked they fitted them right. but i felt like my previous set of tires had some of the rear tires going past the fender flares just slightly if i'm not mistaken. might be my imagination so wanted to double check with other folks that have at least 21s and the staggered fit
#54
Virginbenz (07-09-2024)
#55
Online tire websites allow search by vehicle or by tire size. When I select ‘by vehicle’ then every website I’ve tried in the US and Canada does not come up with the size currently on my 450e (275/55R19). For example, discounttire shows only 255/50 for 19” diameter.
Meanwhile, if I search by size I am subsequently encouraged to enter the vehicle and, if I don’t, I get a warning saying that ‘fitment’ cannot be guaranteed. One site tells me “This tire DOES NOT Fit or may be too aggressive for your 2024 Mercedes-Benz GLE450e 4Matic’. (This note came up for Pirelli Scorpion Zero All Season, the tires shipped with an Audi Q7.)
So… what could go wrong if I buy a tire based solely on ‘275/55R19’?
Notes: Yes, I will be going in person to get this done, I just want to know the answer to this question beforehand. Yes, I’ve bought tires before and have done nothing different than matching the parameters on the tires to be replaced, even for custom wheels on a BMW. I’m assuming that the near uniform insistence in matching the vehicle brand/model/trim is a CYA for the tire supplier…. just want to know for sure.
#56
https://www.mbusatirecenter.com/
#57
19" tire sizes
maplesyrup (07-22-2024)
#58
#59
Did you try this
I agree with Greg from above and disregard the 255/50 suggestions and go with the bigger sized 255/75, it's a much better proportion and probably a better ride due to additional side wall. The required load rating from what I've seen is typically XL, I don't think I've seen anything other than that.
