Dashcam issue
Dashcam issue
I have a 128G USB-C drive plugged in. With automatic loopback, once the drive is full with videos, it is supposed to overwrite. Instead, it keeps giving out errors
"Automatic dashcam recording could not be started"
"Insufficient memory available. Please change the storage medium"
"The selected storage medium has a fault"
Any thoughts on how to fix this?
The following 2 users liked this post by BlueYonder:
PLINYELDER (08-15-2023),
S.W (03-18-2024)
I can't imagine the usb stick making a difference with automatically deleting old files to make room for new ones. It has to be software related. Although I am hesitant to ask for an update because my "Loop" recording starts automatically, which orgianlly did not. I have read many posts on here, complaining, about dash cam needing to be manually started each time.
Has there ever been a solution to having the camera auto start when you start the car - or does it need to be manually started each trip ?
Since I’ve own the 2024 gle, camera starts automatically and loops when recording and auto delete the old ones. If you want to save a video, you’ll need to manually save the video you want. I believe mb dashcam records 20 or 30 seconds long videos at a time
MY 22 GLE450 - Auto Records, but doesn't auto delete.Received a message this morning that recording couldn't be started due to USB drive being full. I couldn't find a setting to auto-delete.
MY 2022 - There is a solution because mine didn't initially auto start. Dealer said it no longer does that. However, after several trips back for issues with dash cam and AR, it just started auto-starting one day, and has been doing it ever since. Ask dealer if there is a software update.
PhilipHanser (08-11-2023)
the video making it easy to pick the ones you might want to save. They are also time and date stamped in the file name.
jhoang1990 (08-09-2023)
ok that’s what it is. I looked at it the first day but forgot how long it recorded for
My order of 2024 GLE 450w has deleted the camera twice when tried on this order. Advised "No chips" or they are using the camera chips on their higher end vehicles. MB cameras are only 1 channel and they do not offer any others such as front and rear. Probably will consider after market.
https://blackvue.com/
MzLynn (08-12-2023)
