Just got my 450e
Old 10-01-2023, 11:22 AM
BlueYonder's Avatar
2024 GLE 450, 2015 X5 35d, 2009 SLK 300
The tax credit requirements for a leased vehicle are much more lenient. The tax credit belongs to the dealer not the person leasing the vehicle. It appears that BMW has chosen to pass the credit on to the customer.
Old 10-01-2023, 06:48 PM
mikapen's Avatar
Received 1,637 Likes on 1,206 Posts
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
That makes no sense at all, even with Bureaucrats writing the rules.
It either qualifies or not.
I can see the administration favoring &nion shops, but BMW isn't that either.
Old 10-01-2023, 06:50 PM
mikapen's Avatar
Originally Posted by TexAg91
I understand the reason is the battery in the 450e doesn't meet the "critical mineral and battery component requirements." Specifically, to be eligible for the credit in 2023, at least 40% of the critical minerals by value – includinglithium, nickel, manganese, graphite and cobalt-- in the vehicle's batteries must have been extracted, processed or recycled in the U.S. or in a country with which the U.S. has a free trade agreement.
To qualify for the tax rebate, a vehicle must:
  • Have a battery capacity of at least 7 kilowatt hours - Check
  • Have a gross vehicle weight rating of less than 14,000 pounds -- Check
  • Be made by a qualified manufacturer. - Check
    • FCVs do not need to be made by a qualified manufacturer to be eligible. See Rev. Proc. 2022-42 for more detailed guidance.
  • Undergo final assembly in North America - Check
  • Meet critical mineral and battery component requirements (as of April 18, 2023). -- ?
BMW's X5 PHEV does...so that is aggravating.
Da Fine Print.
Makes no sense either. All of the above uses child labor and destroys the environment.
BenzNika (10-05-2023)
Old 10-01-2023, 08:05 PM
BlueYonder's Avatar
It may not make sense, but that was one of the things in the so-called “Inflation Reduction Act”
https://www.forbes.com/wheels/advice...-credit-lease/
Old 10-01-2023, 10:34 PM
mikapen's Avatar
Ah, the IRA. Another Vote Before You Read It bill - our chosen Bureaucrats will make it read right.
Different pockets to feed next election, I suppose.
Good thing we have two years of politicking left, to see who the big donors will be. It's always fun.
Thanks for the link.
Old 10-01-2023, 10:48 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Talking
Da Fine Print.
LOL -- how long has it been since Congress actually made sense?
The following 3 users liked this post by TexAg91:
BenjaminKohl (10-02-2023), BenzNika (10-05-2023), mikapen (10-02-2023)
Old 10-02-2023, 02:13 PM
  #32
F18BEN's Avatar
2021 AMG GLE 53 Coupe, 2024 GLE 450e SUV
Love your car. I just ordered one in Alpine Grey. Good Luck!!
Old 11-06-2023, 11:54 AM
  #33
RomanK's Avatar
2024 GLE 450E
I just picked up 2024 GLE 450E as well. I have 11.6kw Level 2 charger at home, but car won't let me charge above 7.6kW. Anyone else has this issue?
Old 11-06-2023, 02:54 PM
  #34
ncgent's Avatar
2024 GLE 450e, 2019 C300W4
Mine charges at 9.6 kw rate which is the official published rate. Charging initially starts at a lower rate but quickly adjusts to the 9.6 rate. My level 2 charger provides 40 amps continuous output, but the charging rate itself is determined by the 450e onboard electronics.
Old 11-06-2023, 03:01 PM
  #35
RomanK's Avatar
2024 GLE 450E
GLE 450e AC Charging Issue
Thank you for getting back to me. I am on day 4, roughly 200 miles on all electric, maxing out at 7.6kw charge rate. Do you recall when did your charge rate moved to 9.6kw, was it after several days or weeks?
Old 11-06-2023, 03:46 PM
  #36
ncgent's Avatar
Mine has always charged at that rate. Each charge session begins at a lower rate but the increases to the 9.6 kw rate. I usually keep my battery level between the 80% and 20% range but on occasion exceed that depending on what I happen to be doing.
Old 11-08-2023, 09:45 AM
  #37
stktyz33's Avatar
MY2024 GLE 450
re: charging rate.
I heard that EVs will automatically reduce charging rates if they sense a voltage drop above certain threshold. I.e., it may be worth plugging it into some other circuit and/or have your electrician they the existing one.
Old 11-08-2023, 04:31 PM
  #38
RomanK's Avatar
2024 GLE 450E
Are you based in USA? Any chance you can share a picture with charging speed? I spend days on this issue, and dealer now tells me that 9.6kw is not possible to achieve in North America, only in Europe.
Old 11-12-2023, 12:46 PM
  #39
ncgent's Avatar
Screen shot from MercedesMe app from charging today. This is usual rate of charge.
Old 11-12-2023, 01:20 PM
  #40
RomanK's Avatar
2024 GLE 450E
thank you. I am in Canada, we don’t even have app support to view charging status for GLE 450e, impossible to activate.
Old 11-12-2023, 01:28 PM
  #41
ncgent's Avatar
To answer an earlier question you asked, yes I'm in the USA. Same charging data should show on your dashboard. On my vehicle this screen with essentially the same information as the app automatically activates when charging is initiated. The mobile app on my iPhone is much easier to use plus the data can be viewed remotely as well as modifications made to the settings.
Old 11-12-2023, 01:32 PM
  #42
RomanK's Avatar
2024 GLE 450E
this is what we get in Canada for 2024 GLE 450e, message to activate. When I try to activate it goes no where.
Old 11-16-2023, 08:39 PM
  #43
RomanK's Avatar
2024 GLE 450E
The app this morning got activated, so now I can see the state of charge - MB Canada also called me on the same day to advise that the issue has been fixed. However, I am still limited to 7.5kw charge rate, hope to get this resolved soon.
Old 11-26-2023, 02:02 PM
  #44
cometguy's Avatar
XC60 T8 ER; pondering GLE 450e
I do not understand what that means: "In order to use the charging features in your vehicle, you must first activate the Mercedes me Charge service."
The five GLE 450e vehicles that I have test-driven in the last two weeks (at four different dealerships) all charge off level-2 chargers at the dealerships.
I'm waiting to test-drive one to a DC-fast-charging station to see how fast-charging works (or doesn't) in this vehicle. It makes no sense to me,
as a three-non-MB-PHEV owner, that you have to "activate" a "service" online before charging your vehicle; that has not been the case for any other
non-MB PHEV or BEV that I have driven (and we're talking a LOT of EVs that I've owned and test-driven).
Old 11-26-2023, 02:03 PM
  #45
cometguy's Avatar
Originally Posted by Alan M
Sadly, my 3 day old car - would not charge - i tried 3 different chargers.
on the EQB loaner, my charger at home worked fine..
You have a 2024 GLE 450e? And it didn't charge at the dealership? You didn't try charging it before you bought it?
Old 11-26-2023, 02:05 PM
  #46
cometguy's Avatar
i was told no go on tax credits..
PS- love the car. with 550 miles, have used gas for 5 miles only, rest on battery
What are you getting for all-electric range off a single charge? (I'm talking real-world miles, not computer-screen estimates.)
Old 11-26-2023, 02:41 PM
  #47
RomanK's Avatar
2024 GLE 450E
i am in Canada, stating range in km
- at temp above 10c (40f?) 85-95km
- at temp near 0c (30f?) 70-80km
For daily commute under 60miles, it’s pretty much all EV car. see my stats below.
the MOST disappointing part, I cannot get car to charge above 7.6kw, and it’s advertised with 9.6kw. It does not matter which charger I use, state of battery or other conditions.
Old 11-26-2023, 10:39 PM
  #48
phillip04S430's Avatar
2023 EQS580 SUV, 2010 S550 4M,2004 S430 4Matic(traded), 2024 GLE350 (traded), 2020 GLS450(traded)
How is your 450e starting in the cold morning when heater has to start to warm up the interior? In Minnesota, the winter here is so long (8 months of the year) and the ICE has to warm up in order to get any heat to warm the interior up. How do PHEVs produce heat in the cold start if only using battery?
Old 11-26-2023, 11:18 PM
  #49
RomanK's Avatar
2024 GLE 450E
Must be using battery to power heating elements. You can program the car to be pre-conditioned at scheduled time or on demand, and when it’s plugged in - it will use grid power to warm up. I will play with this feature this week.
see below - car scheduled to be warmed up by 8:18am tomorrow, or can be manually activated to reach target settings.
Old 11-27-2023, 12:08 AM
  #50
Thanks for your answer.
I will stop by local MB dealer and testing it. Tomorrow will be cold here; single digit wind-chill. May be a good time for conversation with a Salesman.
Quick Reply: Just got my 450e
