48 Volt Battery!!!!!
Old May 21, 2024 | 06:44 AM
TonyF61's Avatar
2022 GLE 450
I am working on getting better answers.
Old May 22, 2024 | 07:59 AM
TonyF61's Avatar
2022 GLE 450
I left a message with SA, yesterday, asking if the actuator was replaced and what it does. Also asked if coolant temp was a result of that. I received a text back stating "Just a reset".
Doesn't seem like I am going to get anything more out of them.
Old May 22, 2024 | 10:23 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
That's unfortunate but not super surprising given that most places are a month out to get in. They just want to get the vehicles in and out not understand what happened.
Old May 22, 2024 | 11:07 AM
mikemdd's Avatar
2022 GLE AMG 63 S
Appreciate your updates and efforts to understand the issue. We are all in the same boat and can learn from each other things to watch for. I just had the 48v recall done last week, like you, and just completed a 2000 mile trip from Chicago to N Idaho. Fortunately no issues, but your experience was on my mind the whole way. Glad to hear you have had no other issues.
Old May 22, 2024 | 11:48 AM
jkaetz's Avatar
Referenced from: https://mbworld.org/forums/gle-class...errerid=436956
Cause 5: This will Always have fault code B183371 but different from cause 2 and 3 -- it will Not have B183349, B183319, or any other faults in the 48V battery. This will only have fault B183371 in 48V battery. Cause 5 is from the 48V battery detecting an abnormality which then causes the 48V battery to disconnect itself. The disconnected 48V battery then causes subsequent symptoms: Limp Home Mode, overheating, A/C not blowing cold, or loss of acceleration
Based on what I know about the battery technology, this sounds like they are overly cautious shutting down the 48v battery if a 48v actuator of some sort can trigger a battery disconnect. It also sounds like a software disconnect since a restart seems to have cleared the issue.
Old Jul 14, 2024 | 11:10 AM
BlackIce999's Avatar
2024 Mercedes GLE63s
48V battery failure
My new 2024 Mercedes GLE63s (7 months old, 4500 miles) barely made it back home this morning. I was on the highway about an hour from home when a message popped up in red saying 48V battery malfunction. It got worse from there as everything started falling and I then got a “STOP VEHICLE” message. I was able to limp home and a flatbed is coming to pick this up. Have any of you had similar problems with a 2024?
Old Sep 23, 2024 | 01:48 PM
  #32
Mostell's Avatar
Exact same issue yesterday for me on a 2024 AMG GLE53. 48V Battery Warning -- then went into turtle mode -- then coolant overheated and a "pull over immediately" warning. Pulled over and I let car cool down. Afterwards water pump never kicked on and recirculate as temp sky rocketed quickly. Towed to dealer. Unfortunately I missed the recall. I will add I had two different 48V issues. First went way after restarting car. Second turning into a "fuel trim level" issue and had a fuel injector replaced.
Old Sep 23, 2024 | 01:51 PM
  #33
nextmilenium's Avatar
2021 GLE450
Please keep us posted on what the dealer does.
Old Sep 24, 2024 | 02:56 AM
  #34
RedJet's Avatar
2018 Ferrari 488 GTB, 2020 Mercedes GLE450, 2025 Tesla Model 3, 2022 Aston Martin DBX
Same issue on my GLE450 at 26k miles. Got those messages including a "STOP VEHICLE" message that sent it into limp mode. Barely made it home and had it dragged out of my driveway this morning. This thing's already spent 3 months at the dealership from other issues, at this point I might as well start telling people I own a GLC loaner instead of a GLE. Getting tired of it
Old Sep 24, 2024 | 08:28 AM
  #35
Vbrooklyn007's Avatar
Gle53
Thankfully, I purchased an extended warranty. Now, I'll have to see if it is covered.
If you don't mind sharing, what kind of extended warranty did you get, was it from Mercedes or Independent company?
Old Sep 28, 2024 | 02:00 AM
  #36
RedJet's Avatar
Update on my GLE450, just heard back from the dealer. According to them, they did some sort of software test that led them to replace the entire 48v battery. Picking up the vehicle on Monday. Will further update then.
Old Sep 30, 2024 | 11:57 AM
  #37
TonyF61's Avatar
2022 GLE 450
Yes, it was from MB - 5 year/100,000 miles
