450e Charging device
Old Jul 16, 2024 | 04:46 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Charging device.
This is the charging device that came with my CPO car. Do you folks have one of these or an MB branded one? It’s showing 7.3 kw with a standard 240 outlet. The manual shows an MB branded one.
Thanks.
Old Jul 17, 2024 | 08:27 AM
parato's Avatar
2024 GLE 450e
Originally Posted by Elvisfan0108
Charging device.
Thanks.
My purchased new 450e came with a 120v charging cable only. I use the cable when at our vacation home.
I have an L2 charger installed in my home parking spot. It's charge rate is set to 6.6kw because it is fed by a 30A breaker.
Old Jul 17, 2024 | 08:30 AM
maplesyrup's Avatar
GLE450e
Mine looks the same. I plug into a 120V/15Amp outlet and the car reports 1.1 to 1.2 kw, so it is pulling about 10 amps. The other pigtail that came with the charger is for a NEMA 14-50 socket (240V, 50amp). [I didn't look at the pigtail, but the Amazon product page states this]
Your 7.3kw means it is pulling 30amps, while the socket and wiring would support 40amps. Noted elsewhere (perhaps on this forum), the charger doesn't know the amperage of the circuit and pulling the minimum of the common options is a safety measure.
Edit: just saw the previous post from parato, which casts some doubt on my last sentence as I can believe that 240V/30amp residential circuits are common. This would lead to a draw of 5760 volt-amps (240*30*0.8).
Old Jul 17, 2024 | 08:43 AM
maplesyrup's Avatar
GLE450e
6600/240 = 27.5 amps. This is 91.7 % of 30, and ... is not good. The National Electric Code says you should not exceed 80% for continuous load.
Old Jul 17, 2024 | 09:01 AM
parato's Avatar
2024 GLE 450e
You are correct. My typo. The breaker is 40A. We have a 3phase 208/120v supply. The charger is set to 32A. 32 is 80% of 40. 32x208=-6.6Kw.
Old Jul 17, 2024 | 04:07 PM
someone ripped you off. The car should have come with 2 pigtails. The dealer has figured out a way to make a few extra bucks.
Old Jul 17, 2024 | 08:11 PM
parato's Avatar
2024 GLE 450e
Thanks for the heads up. I did not know that, and will go back after the dealer.
Old Nov 16, 2024 | 10:18 AM
Capt Milks's Avatar
I just tried a Mustart charger on my 50A wall socket. It is rated at 40A. I am seeing a higher charge rate compared to the factory charger, 7.6kw vs 9.6kw. My understanding is the GLE450e can support the 9.6kw charging. Am I wrong? Also the wiring on the Mustart is much thicker. Now the difference in charging times doesn't matter to me. Is it better to charge at the 7.6kw or the higher 9.6kw? Some say the DC charging can degrade the battery quicker. would that be the same on 7.6 vs 9.6?
Old Nov 22, 2024 | 07:30 PM
Angelo6379's Avatar
2016 C300 Sedan
What time frame are you all seeing for a full charge from zero or close to it using the charger the car came with but with 220 with a 40 breaker? I’m currently using 110 and it takes more than 24 hrs. So I’m seriously considering having the 220 installed with an 40 breaker and trying to figure out if to keep the same charger or get a new one. Thanks for any input.
Old Nov 22, 2024 | 08:01 PM
maplesyrup's Avatar
GLE450e
If you are in the USA or Canada, you really should say 120 and 240, and not 110 and 220. The transition to 120 and 240 nominal voltagesended about forty years ago.
Capt Milks's Avatar
I have a 220 50 Amp breaker. From less than 10 percent to 100 percent takes about 2.5 hours. Using the Mercedes charger. It is a little quicker on the the mustard as it is a 40 Amp charger.
Old Nov 22, 2024 | 10:37 PM
Angelo6379's Avatar
2016 C300 Sedan
Noted thanks!
Old Nov 22, 2024 | 10:39 PM
Angelo6379's Avatar
2016 C300 Sedan
Ok so def worth getting done. Using the included Mercedes charger do you recommend the 50amp breaker then or is that just bc the Mustard is 40 amps?
Old Nov 23, 2024 | 08:07 PM
SoCal Living's Avatar
2024 GLE450e
This is the correct one. Should have a 220/240 volt and a 110 volt adapter so you can use with both plugs.
Old Nov 26, 2024 | 09:33 AM
parato's Avatar
2024 GLE 450e
Not exactly. Yes single family homes are 120/240. 3 phase Wye nominal low voltages 120 volts/208 volts, and 277 volts/480 volts, are commonly available for commercial and lite industrial buildings. In my condo building the available voltages are 120/208.
Old Nov 26, 2024 | 09:36 AM
parato's Avatar
2024 GLE 450e
In Canada I was supplied a 120V cable only. After reading here that a 120/240(208)V cable is available I went back to my dealer and was told that MB has started supplying that cable in 2024 for the EQ series but not the Plug In Hybrid and it would be a $750 option. Looks like I need to speak with MB directly.
Old Nov 26, 2024 | 12:34 PM
That’s interesting, I know in Canada the fast dc charger is an option. It’s standard in the U.S.. However, the 240 cable should be included.
Old Nov 26, 2024 | 09:44 PM
maplesyrup's Avatar
GLE450e
Inside a unit (apartment?), what receptacle is used? (by "inside" I mean one you didn't specifically request, such as you might at your parking space(s).)
Old Nov 27, 2024 | 08:54 AM
parato's Avatar
2024 GLE 450e
Sorry for being vague.
In the condo building residential outlets are 120v.
In the parking garage when we installed level 2 chargers they were connected to a 208v supply.
By the way, many multi unit buildings don't have sufficient capacity to provide lavel 2 charging at every parking stall.
To address this we installed chargers that are networked together and ensure the total charging load does not exceed the buildings rated supply. When the demand (too many cars plugged in at once) exceeds demand the charge rate is reduced to stay within the supply limit. When some car finish charging the rate is then dynamically increased.
