Which tires to order with 2025 GLE 450e
I’m not a big fan of run-flat tires and I think all-seasons ride better. In either case, I don’t like not having jack or spare, but I guess there is no choice with the PHEV. Does anyone have real-world experience or recommendations with either of these tire options? Thanks.
I'm of the opinion that runflats provide a false sense of security anyway. They might not need air if they're punctured, but a nasty pothole or curb can put bulge in a runflat's sidewall and leave the car just as disabled as a flat would. The stiff sidewall also transfers impact forces to the wheel, making it more vulnerable to bending or cracking. Factor in the firmer ride, higher unsprung weight, shorter tread life, higher price and limited availability, and it's no wonder automakers aren't as high on runflats as they once were. As batteries continue to fill space formerly reserved for spares, fix-a-flat kits will likely displace runflats for all these reasons. Until these become readily available, that is ...
Remember, if you get damage to a run flat tire and run it while it doesn't have air, it cannot be repaired and must be replaced.
