High diesel consumption at idle
When I shift to park (P), the consumption decreases to 2.3 l/h, but shifts back to 3.2 l/h when I return to drive (D). I'm also considering the injectors, but typically, injector issues lead to decreased fuel delivery, not increased. Any insights on this?
I noticed that since I used liqui moly dpf cleaner. Will it make dpf burning more often? I still do not know how this additive work.
the interesting thing is the car will retry to do the burn until it get 0% even you stop the car overnight etc. Does not matter in freeway or short drive. It will retry as much it completed.
The way to know when dpf is burning is either idle the fuel consumption is higher than 2L/h
and while driving and release accelarate padel the idicator wont go to charge area(red area)
Do not worry about the interrupt it because I tested that
- stopping car during the process and I left it overnight it started straight away when engine starts until 0% soot.
- same as stop the car go to shopping come back and it also start again.
Anyway, I wish there was a way to easily initiate the burn from some settings menu. Then I could run it when I know I have a long trip ahead of me.
