Poll: Has your mild-hybrid GLE ever "stalled" at a stop/red light?
It's the second time since I own my 24 GLE 450 that this happens to me: come to a complete stop (i.e. red light), the engine will shut off as expected, but then once you hit the accelerator there is no response and the dashboard gets illuminated like a xmas tree. Restarting the car (ignition off / on) fixes the issue. Engine light is there for a couple of days and it goes away, like nothing happened. This has happened to me at ~8k miles and at 13k miles. The first time I had the car in the dealership for several weeks, they ended up replacing the ground cable for the 48v battery after lengthy diagnosis of the issue with MB Germany.
Now I wonder if this ever fixed anything, or it was just shots in the dark since all the diagnosis for the different subsystems were looking good. I wonder if there is some software issue with auto start/stop where once in a blue moon planets will align the wrong way and it will lead to this complete stall.
Looking back in the forum I've found several folks reporting similar issues: https://mbworld.org/forums/gle-class...ing-issue.html
So here is the poll: if you own a mild-hybrid GLE (450 in my case) have you ever experienced this problem?
Yes, a loose ground can cause Christmas Trees and more. I'd say the odds of having if fixed are good.
There was a recall on a very small number of '20 450's (18?) and a TSB during 2021 for grounds. The first was for calibration of a new tool (they knew which cars the new tool was used on). The TSB wasn't so specific, and I didn't see what might have been the cause.
Both fixes seemed to fix the situation, at least based on posts on the forum.
This time around I only saw the Christmas Tree, no companion message like the other time ("48V Error" or something along these lines).
So either the ground cable was not the root cause or this is due to a different problem. In any case this kind of power loss incidents are not acceptable :/
https://www.nhtsa.gov/report-a-safet...clsrc=ds#index
As mentioned above, you may want to consider disabling the start/stop feature. I had it disabled and "remembered" at each startup via coding w/ benzninja, fuel savings was negligible, and was a pain during heavy traffic conditions.
It doesn't actually disable, but the reminder pops up on the screen - "restore S/S" or similar, but you still have to move your finger.
To the OP, have it checked out at the dealer or a trusted independent. There are likely stored codes even if the engine light isn't showing.
Compared to my 2022 E450 All-Terrain Wagon, the auto start/stop in the 2024 GLE450 is very imperceptible, and you barely notice the car starting up from a stop. In the 2022 E450 you do feel it a bit. In the E450, I tend to turn off the start/stop function, while in the 2024 GLE450, I don’t feel the need to turn it off, since you barely notice it.
Something I noticed is that I always use the HOLD function when stopping in red lights, etc. I wonder if this makes it more prone to happen – i.e. if the car goes to a semi-parked mode and then there are more checks performed before reigniting the engine when pressing the accelerator.
I think the only way forward is to bring it to the dealership right after this happens again and the error code is still there. But it feels an elusive one, hard to root cause.
A dealership visit/scan with Xentry is likely the only way to dig deeper.
