Amber light while charging with Webasto
Old Jan 19, 2025 | 07:56 PM
Angelo6379's Avatar
2016 C300 Sedan
I have had my 450e for about 2.5 months now and I am not sure if this was happening since day one and I never noticed it or if it just started recently.
While using the Webasto charger with the 220/240 I am getting the amber light and blue light illuminating. When this happens the charge goes from around 7-3.5kw. I feel the unit and cable warm/hot.
I looked up the manual and the closest I can get is amber on and blue pulsing but mine is not pulsing. It’s states overheating.
just curious if this is normal? Are others experiencing it as well or if I need to have this checked out.
thanks
Old Jan 20, 2025 | 03:05 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Hasn’t happened to me. I would check the outlet.
Old Oct 1, 2025 | 12:36 AM
whatsgoingon's Avatar
Amber and blue light
Hi, I just got my Gle 450e and noticed the same amber light with steady blue light on the webasto portable charger. Any answer to why this happens?
i wonder if it’s a fault on the outlet installation.. I had an electrician install 50amp outlet instead of 40amp.. the electrician said it would be ok.
Old Oct 1, 2025 | 12:53 PM
I take it back. Apparently this is common. The charging watts also change all the time. Maybe it’s the heat.
Old Oct 1, 2025 | 01:49 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Whenever the charger I use with my Tesla acts up, I recycle (reboot) the power to the charger. Seems to solve the problem. Worth trying with your Webasto charger.
