Infamous P06DA00 code - oil pump valve - with CEL - Indy said, “don’t worry about it”
Old Apr 12, 2025 | 12:21 PM
Go Dawgs's Avatar
AMG GTC
My wife has a 2020 GLE350 with around 55K miles on it.
The check engine light came on a couple of weeks ago. I scanned and the only code showing was the notorious P06DA00 oil pump control valve and wiring harness one.
A couple of days later, check engine light turned off by itself.
A week later, CEL came back on.
Took it to our indy mechanic shop and they said, “it’ll be a $3K fix, we cleared the code, keep driving it and don’t worry about it.”
So we did!
Unfortunately, the check engine light came back on and has remained.
No noticeable drivability issues.
I’ve read that the code shouldn’t cause a CEL, and if it does, it’s a problem.. but not sure what to believe.
I can’t find clarity - can the code be ignored when a check engine light is present, if no drivability issues are present?
Old Apr 12, 2025 | 01:43 PM
W205C43PFL's Avatar
So we did!
Yes and no, you can technically leave it, but you need to make sure it is in normal oil pressure mode, more on it here: https://mbworld.org/forums/w212-amg/...ml#post9120782
The benefits and reason why you don't even want this solenoid working is in the FAQ on the first page.
Old Apr 12, 2025 | 02:09 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
If your state requires regular emissions testing. The car will not pass with an active CEL.
Old Apr 12, 2025 | 03:02 PM
Go Dawgs's Avatar
AMG GTC
I believe this is exactly what I needed and wasn’t able to find in other threads I looked at. Thank you so much!
Old Apr 12, 2025 | 04:47 PM
W205C43PFL's Avatar
You're most welcome : ) happy to help. Make sure to do the oil pressure testing as mentioned.
Old Apr 12, 2025 | 04:48 PM
W205C43PFL's Avatar
This is a good point, in that specific case, OP should plug a dummy solenoid externally, link is also in that big thread so the CEL is off. Obviously make sure pressure is good first before doing this.
Old Apr 12, 2025 | 04:51 PM
W205C43PFL's Avatar
nevermind, might as well link the link, right here: https://mbworld.org/forums/w212-amg/...ml#post8908497
Do manual oil pressure testing, if it is good, then unplug the external harness and plug the harness to this dummy solenoid, ziptie it somewhere safe outside the engine.
Old Apr 12, 2025 | 05:00 PM
W205C43PFL's Avatar
That solenoid in that link will take a while to arrive to the usa though, if you are in a rush, you may buy the oem part from the dealership. Here is the part number: https://cimg8.ibsrv.net/gimg/www.mbw...fefddf925.jpeg
Old Apr 12, 2025 | 05:07 PM
PeterUbers's Avatar
Keep in mind that if the wire harness has oil in it from a leaking oil solenoid, this could be a source of oil creep into your engine harness, which is a significant problem for your car.
As mentioned above, inspect the connection to this oil solenoid and see if oil has crept into the wiring harness. If so, this is fortuitous because you could disconnect this solenoid permanently, and you can attach a dummy solenoid to it and never have to deal with ongoing creep of oil into the engine wiring harness.
Old Apr 12, 2025 | 05:22 PM
JettaRed's Avatar
Veteran: Army
2019 and newer cars will trigger the CEL in addition to throwing the P06DA00 code.
To get rid of the CEL, attach a dummy solenoid as recommended. (The "DO NOT CONNECT" tag is to alert any mechanic to not reconnect the wiring harness to the solenoid connector on the engine block.)
File Type: pdf
Old Apr 12, 2025 | 06:57 PM
W205C43PFL's Avatar
Didn't occur to me that thing can rust
Old Apr 12, 2025 | 09:38 PM
JettaRed's Avatar
Veteran: Army
Normally it would be submerged in oil. Or at least not exposed to the elements. Plus, that's my cheapo AliExpress solenoid. I am glad I put heat shrink over the critical part.
Old Apr 12, 2025 | 10:00 PM
W205C43PFL's Avatar
I see. So with the oem one it might not rust?
Old Apr 12, 2025 | 11:17 PM
JettaRed's Avatar
Veteran: Army
It still might rust. I will check my other car tomorrow to see if it is rusted, as well. It doesn't bother me about the rust because the part is sacrificial anyway. Having the heat shrink on it should protect it from the elements.
Old Apr 13, 2025 | 05:13 AM
W205C43PFL's Avatar
I understand the rust is not a big deal (on this) but still interesting to see, thought it was made of aluminum.
Old Apr 13, 2025 | 05:21 AM
W205C43PFL's Avatar
Actually, on a second thought, given as you mentioned this is bathe in hot oil, it can't be aluminum as it will bend.
Old Apr 13, 2025 | 10:41 AM
Go Dawgs's Avatar
AMG GTC
Hey, my friend!
I have a good OBD2 scanner. The scanner has live data mode and I was thinking you could view oil pressure this way. Unfortunately, I don’t think the scanner includes that data point.
What tool did you use to check oil pressure?
Thanks again.
Josh
Old Apr 13, 2025 | 10:50 AM
JettaRed's Avatar
Veteran: Army
Hey, my friend!
Thanks again.
Josh
I think only some of the newer engines, like the M256 3.0 in-line 6, have oil pressure sensors. Previous engines do not. There is an oil pressure test port that requires a mechanical gauge be connected. I could try to look up the procedure for your car if you post your VIN or just give the full model designation, e.g., 167.XXX.
Old Apr 13, 2025 | 10:53 AM
JettaRed's Avatar
Veteran: Army
Old Apr 13, 2025 | 10:54 AM
W205C43PFL's Avatar
Would be 167.359 : )
Old Apr 13, 2025 | 10:55 AM
W205C43PFL's Avatar
Hey, my friend!
Thanks again.
Josh
Hello : ), forum member JettaRed replied with instructions to test it, enjoy the car : )
Old Apr 13, 2025 | 11:03 AM
W205C43PFL's Avatar
Oh wait, hold on, correction, OP has a GLE 350 so it is an M264, the model will then be 167.149 for 4MATIC and 167.148 for base RWD.
Old Apr 13, 2025 | 11:10 AM
JettaRed's Avatar
Veteran: Army
So, it looks like it's a real PITA to do it on the M264 (see attached).
File Type: pdf
Old Apr 13, 2025 | 12:08 PM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
during the test are you with 5w40 or 50 as i see on 1500rpm you have decent 40+psi pressure which is good
Old Apr 13, 2025 | 12:23 PM
W205C43PFL's Avatar
Hmmm, in that case, OP might want to get an independent shop to do it.
