Steering Wheel Replacement
I'd actually prefer a flat bottom wheel with a little larger grip diameter.
Has anyone made a swap?
Did you go with an aftermarket wheel or replacement with an AMG wheel off of a 53 or 63 Coupe?
If you went aftermarket where you happy with the brand you choose? Any regrets? Any "wish I had done this" moments?
I am a little apprehensive to make this change and trust the fit and compatibility of anything aftermarket. However if anyone here has practical real experience I'd welcome feedback?
Thank you
Thank you
if it does your aftermarket options are limited. As far as I know there are zero aftermarket manufacturers for the touch sensors pad, and the dealership also does not sell it separately. You could still run an aftermarket wheel but you would have to disable the feature from showing up on your dashboard.
if you don’t have that option then a retrofit to a amg wheel is easy peasy. We have done a couple
can checkout RUcarbon on IG
I think Elebest, a sponsor, might also do it.
Other than 266, another thing you need to be careful is the heated wheel, but that won’t cause any fault in clusters, just lose the heating function of wheel.
Go to local dealer show room grip the wheel of a 63 or 53 model, see if you like them. If yes, we have them ready stock.
Mercedes AMG Genuine Brand New Wheel w/wo. heating and/or hand hold sensor. The only bad thing is its unfriendly price.
Thanks.
