2020 GLE 450 transmission, differentials, transfer case fluid?
Old Mar 19, 2026 | 06:21 PM
waskoo89's Avatar
2020 GLE 450
Unhappy 2020 GLE 450 transmission, differentials, transfer case fluid?
Hello,
I need someone to confirm what are the correct oils and quantities for my 2020 GLE 450 VIN 4JGFB5KEXLA169883 ( 95k km )as I'm facing some issues (whining noise while steering on low speeds and accelaration on corners) after rear differential/transfer case oil change.
The noise existed before as well but it was really quite at first.
Interesting fact is that the issue reproduces only after the car is once well warmed up. No noise on cold oils ...
This is what was recently inserted into my car :
Engine - MB 229.52
9G tronic automatic transmission - MB 236.17
rear/front differential - MB 239.71/239.72 capacity ?
transfer case -239.41
I just want to ensure the oils are the correct ones.
All oils were replaced back in November . Noise became more loud . That's why i did it once again and replaced it this week. The oil was not clean only after 10 k km but i didn't saw any particles in it... Just the color was darken.
Currently the noise is way better and not so aggressive like it was before. So the fresh oil works better it seems.
Heard about a secret (internal use only) mercedes genuine friction additive ? Is it worth it to try finding it and add it into the rear diff ?
Thanks for your support !
Cheers !
Old Mar 21, 2026 | 12:41 AM
wildta's Avatar
GLE 580
I'm doing this same work on Monday with my indie. I also asked Gemini AI and he wanted to compare his references to my Gemini AI output. I'll keep you posted. I have a 2020 GLE 580.
Gemini AI output
Gemini AI output
Old Mar 22, 2026 | 09:59 PM
krzyoldgy's Avatar
2020 GLE 450 4MATIC
Pelican Parts have these listed for the Rear differential :
235.61
Note: For cars with (Code M016)
Nothing mentioned for the Front differential, maybe it uses a different oil spec.
https://www.pelicanparts.com/cat/v_m...fferential-oil
Automatic Transmission 236.17
Transfer Case 239.41
Old Mar 22, 2026 | 10:12 PM
chassis's Avatar
2017 GLE350 4MATIC
You all are aware of the operatingfluids aka bevo site correct?
Old Mar 23, 2026 | 02:30 AM
streborx's Avatar
Top Answer: 1
G550
The fluids website is https://redirect.viglink.com/?format...es-benz.com%2F.
Some of the sheets list brands and blends (engine oil), some do not (brake fluid), and some provide very few. Many of the oil brand websites provide MB sheet compliance for their fluids. Every MB chassis seems to have its own set of sheets. As difficult as it is to assemble a list of brands and blends for each application in each chassis, the online suppliers' directories are frequently incomplete and in error, even when checking the compatibility of MB OEM fluid p/n's. As confusing as MB's fluids are, BMW hasn't even a fluids website and constantly changes which fluids are suitable for which vehicles. Even dealers are confused.
Old Mar 25, 2026 | 12:45 PM
Roweraay's Avatar
X214
Originally Posted by waskoo89
Hello,
I wonder if the whining sound is a CV joint problem.
Old Mar 25, 2026 | 02:42 PM
waskoo89's Avatar
2020 GLE 450
i was also wondering the same… Car was inspected in two Mercedes Benz specialized maintenance shops and from both places they told me all looks in good condition and they suspect the rear differential.
it’s a fact that after the second oil change on the rear difderential the whining noise is lower .
I assume we’re talking about low quantity of oil, bad oil, bad/heating differential or something like that.
Issue is only once the car is hot and oil respectively is also really hot and lubrication effect get worse because of the high temperature. That’s my observation but i’m not a mechanic.
Thanks for all the replies here ! If i find something else will let you know guys !
Regards,
