Halogen to HID success!
Thanks!
Ken
https://mbworld.org/forums/gls-class...on-lights.html
the conversion looks great, I doubt you'll have any issues with it or your warranty
https://www.theretrofitsource.com/h7...ros-48749.html
Glad I tested before I cut the cap. I tested the Morimoto canbus H7 Elite with a 12 volt battery and they work perfect. I determined the + side was the larger wire at the plug and hooked up the system on one side. Turned on the lights and the HID came on for a few seconds, went off, came back on for a second, then stayed off and I got the low beam out warning on the dash. I tried it a couple of times. I guess there is not enough power to drive the ballast (35 watt ) directly with the canbus system. Dam. Anyone else have trouble with the Morimoto canbus without relays??
I have a 2016 GLE 350 with stock Halogens.
Ken
Ken
Maybe I just need the capacitor link?? I will post a follow up when I get it sorted.
Ken
Ken
I also have a 2016 GLE 350, no low beam out warning after the ballast was replaced. Im using the 50w version.
Did you use the capacitor link?
