GLE Class (W166) Produced 2015-2019
HK set up when you plug in your phone
Old Feb 23, 2017 | 04:29 PM
TheHolyman's Avatar
GLE 350
All,
I have set up the logic 7 & equalizer plus bal/fade for when I use the radio. For Bluetooth you have to set up separately as I found out when I started using blue tooth and thought it was flat. After checking the settings they where all default. So changed them and then checked with blue tooth device disconnected and it had different settings for radio.
My question is how do you set the logic 7 on and equalizer settings when you plug your phone in and use car play. I cannot get to the setting screen even when i go through the apple play Mercedes car setting button.
It sounds flat also so leads me to believe I have to set this up like blue tooth. Anyone had same issue and worked it out..?
