21" or 22" Wheels?
I don't want to run GLE63 aggressive and I think the stock wheels are 21x10 +53 offset right?
I saw a lot of the aftermarket wheels that are running 21x10 but +40 which I think is too low of an offset - it's going to stick out too much.
Ideally I'm looking for a 21x9.0 +53 offset to run 275/35/21 square or maybe a 22x9.0 +53 with a 285/35/22 square.
Any thoughts on 22" being too aggressive for the chassis? What is everyone running?
the fronts.
It doesn't bother me either, but it might bother others.
I do know that the 22's stick to the road like glue...
ON EDIT: I've been really surprised that these don't ride like a rock either. They are very comfortable, in comfort mode of course.
the fronts.
It's pretty normal for big power cars - even 4WD cars to run a staggered setup meaning the rear tires are wider because usually the torque split is not close to 50/50.
For me I don't want to sacrifice too much ride comfort and since the GLE350 doesn't make much power there isn't a real need for much wider tires then I would say a 275 or 285 width. Also excessively low offset such as some of the +30's I'm seeing on the forums will lead to premature hub / bearing wear...
So I just wanted to get some feedback as to what everyone's running! Good to know that hte 22's don't ride too bad, that was what I was afraid of!
Gary
GLE63 - 265/45/20
GLE63s - 295/35/21
