GLE Class (W166) Produced 2015-2019
Tire Preassure For GLE350???
Old May 15, 2017 | 11:52 AM
Ride92's Avatar
2016 GLE350 4Matic
I'm a bit confused by the multiple stickers on our car that all have different PSI recommendations. The Driver door jam states about 44psi where as the fuel filler door states 32psi. What is the recommended PSI, and what are people finding as the best PSI for MPG?
Old May 15, 2017 | 03:51 PM
RA112623's Avatar
the correct specs for YOUR vehicle are on the fuel filler cover.
psi adjustments effect ride, handling, tire wear, etc.
i use the specs. good luck, ron
Old May 16, 2017 | 12:52 AM
fabbrisd1's Avatar
A gaggle of MB's
I have my techs set 38psi all around - drive that for 2 weeks - then adjust +/- 2 psi untill you find your "sweet spot".
Fuel filler door is the "official" recommendation - door jamb is manufacturing info - and max recommended tire pressure on the tires is ridiculous.
Old May 16, 2017 | 05:40 AM
yavor's Avatar
Mercedes GLE 350d 4Matic
I found out that for me 36psi is the best ballance between stability and comfort, with the 20" rims at least. Have in mind that 36 psi cold means not less than 40-42 psi after driving an hour on the highway during summer. With 32psi as stated on the fuel door even without passengers the car feels extremely bouncing and in sharp turns I had the sensation that almost I'm going to scratch the rim on the road, and maybe it was not only a feeling...
Old May 16, 2017 | 09:33 AM
nvsocr7's Avatar
GLE 350 4MATIC
34-36 psi is just about right, good balance between performance and handling. My cold and "just drove for a few minutes to the gas station" temperatures are the same. I use the numbers on the fuel door. MPG for me hasn't changed much regardless of tire pressure or comfort/sport. I average about 19mpg (mix highway/local) and ironically, after a reset I was averaging 20mpg in sport vs 19 comfort.
Old May 16, 2017 | 12:04 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
According to many sources, the sticker on the B pillar- the drivers door jamb- is specifically for the tires that came on the car when delivered new. A law since 2003.
The fuel filler door numbers are probably not for the specific tires that came on the car.
But - of course- there is contradictory information on this...
So, I am going with the sticker on the door jamb.
Old May 16, 2017 | 01:10 PM
RA112623's Avatar
it is confusing. dealer said go with fuel door. take a look at two pics. b pillar only has max load. fuel filler has more info, but max load over 100 mph equals the b pillar.
this shouldn't be this hard. and don't get me started on Command
ron
